![]() Drives: 2008 Yaris Join Date: May 2011
Dome/Floor Light and Headlights on Warning Not Working
Sorry for the totally rookie question, but when I have my lights on, turn off the car, take the keys out and open the door, I don't get a warning that the lights are still on which is a huge pain. Also, when I open the door, the interior lights don't come on (yes, I have the switch on the dome set to "door").
Any suggestions??? |
![]() Drives: 09 yaris sedan Join Date: Feb 2011
Do they turn on at all, might be a fuse....just a thought
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
Do any of the doors turn it on?
Will it go on if you set it to the manually on position instead of the door position? |
It goes on when I turn it on and I checked the fuses, nothing seemed out. Like I said, the warning buzzer that sounds if you leave your lights on doesn't go off either, which is a huge pain!!
The switch on the door frame may be damaged, since they work in manual mode.
| headlights not working.... | Judas Iscariot | DIY / Maintenance / Service | 66 | 09-06-2019 12:27 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| Sedan HID Projector Retrofit Headlights | !yaris! | Cosmetic Modifications (Exterior/Interior) | 10 | 10-26-2017 03:31 AM |
| Best Aftermarket Headlights | MadMax | Cosmetic Modifications (Exterior/Interior) | 3 | 06-04-2009 07:50 PM |
| Angel Eyes headlights | Danish Yaris | Cosmetic Modifications (Exterior/Interior) | 9 | 02-13-2009 10:15 AM |
