Old 05-30-2011, 11:49 AM   #1855
Idahotom
Drives: 2008 5 sp. LB
Now that winter and winter fuel is gone, I had my first tank of 45 plus, 45.97 to be exact, going by the same pump at the same station, real gas BTW. 5-sp.
Idahotom is offline   Reply With Quote
Old 05-31-2011, 11:40 AM   #1856
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i had a great tank going
then i got stuck in some bullshit traffic-light inspired traffic when i went to the junkyard the other day...& got a 50.47 my last tank, i was fucking pissed I know i was on a 53 maybe 54 tank on that one all my mileage per fuel levels were 15-20mile more than usual
this new current tank is ruined cuz i've been driving like a jackass
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-31-2011, 03:37 PM   #1857
sickpuppy1
Drives: 2010 Yaris Sedan
While not as good as yours. I was enthused about the mileage from this weekend. Went to lake of the Ozarks and got 43.6 mpg on the way odwn and 46.6 on the way back. both new records for me. 2010 sedan. 2 overweight adults with luggage and coolers doing 65-70 most of the time.
Had about 90-100m miles of 2 lane blacktop that was slower, but also twisty turning too,(love my rear sway bar,lol)
Old 06-06-2011, 10:41 AM   #1858
Woodsman
Drives: 2010 Yaris Hatchback CE
Did a mileage check on Saturday. Less than ideal conditions.
2010 3dr hatchback with 12,000 km ( just under 7,500 miles)
Aprox. 90% highway. First half of the trip in a heavy rain storm average speed 80 kph (50 mph). Return trip mostly sunny with average speed of 110 kph (just under 70 mph).
About 700 lbs of passengers & cargo.
Total distance - 405.8 km or 252.2 miles.
Fuel used - 23.681 litres/5.21 Imp gals/6.21 US gals.
Results - 5.8 litres per 100km/48.41 mpg(Imp)/40.31 mpg (US)
Woodsman is offline   Reply With Quote
Old 06-06-2011, 11:15 AM   #1859
malibuguy
Obsessed with 1.5L
i'm onto a good tank
118.9miles when the first bar went off...i'm usually in the 90s
-96 Tercel 4dr
Old 06-07-2011, 08:06 AM   #1860
STC
"LibertyRides!"
STC's Avatar
I filled-up my tank this morning... click to click with Shell ethanol gas on the same pump as a couple weeks ago. I'm starting to like Shell gas
Gas Tank mile increments (ethanol gas used):
1st Bar drop (8/8) > 135 mi (135)
2nd Bar drop (7/8) > 60 mi (195)
3rd Bar drop (3/4) > 55 mi (250)
4th Bar drop (5/8) > 60mi (310)
5th Bar drop (1/2) > 60 mi (370)
6th Bar drop (3/8) > 65 mi (435)
7th Bar drop (1/4) > 75 mi (510)
8th Bar drop (1/8) > 0 mi (510)
Tank total : 510 miles
Fuel used: 9.666 gallons
MPG: 52.762
Cheers!
~ Mark ~
Old 06-07-2011, 10:42 AM   #1861
STC
"LibertyRides!"
STC's Avatar
^ Correction! I got confused. It was two different brands. Exxon was the last fill... the fill prior was Shell. Shell fill-up this this morning. I'm filling with shell after this tank on the same pump.
Cheers!
~ Mark ~
Old 06-07-2011, 11:24 AM   #1862
malibuguy
Obsessed with 1.5L
i was an exxon man cuz i had a very convenient one on the way to work, but it shut down, so i go to shell now also...
my 2nd bar went out at 205.7 & my 3rd 281.3
-96 Tercel 4dr
Old 06-07-2011, 04:19 PM   #1863
STC
"LibertyRides!"
STC's Avatar
Yes... I like Exxon and Shell. I get the best mileage from using their gas! Excellent job on your 2nd and 3rd bar mileage readings!
Cheers!
~ Mark ~
Old 06-10-2011, 07:56 AM   #1864
malibuguy
Obsessed with 1.5L
4th bar- 331.6
5th bar- 395.4
6th bar-475.7
filled up at 503.9, used 9.355 gallons
53.86 MPG!
that was with A/C use
-96 Tercel 4dr
Old 06-10-2011, 12:03 PM   #1865
yaryarbing
Budget Buster
yaryarbing's Avatar
Drives: 2007 Polar White Sedan
Very Nice, malibuguy.
With AC running during our Maryland heat wave, I pulled 50 mpg out of my '07 ATX sedan.
I ran 545 miles on the tank. 10.9 gallon fill.
yaryarbing is offline   Reply With Quote
Old 06-12-2011, 10:24 AM   #1866
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
Just had by best tank yet. An even 45.0 MPG. I think that's the best I can do.
rick996 is offline   Reply With Quote
Old 06-12-2011, 11:40 PM   #1867
Hershey
Size:  70.2 KB 401.8 miles and a blinking bar . Took 10.05 gallons . So , calculation of 39.98 m.p.g. overall . We have ECO set little lower so we know it's doing better than what it displays . This is the 4 speed automatic .
Old 06-13-2011, 02:14 AM   #1868
Driving pretty hard this tank (smashing it around town and on the freeway, shifting much later than I normally shift, etc), and some AC usage. SGII is reading 36.1 mpg for my afe (average fuel economy). I set the SGII to read a little worse than what it actually is, so I'm thinking it's really ~37 mpg.
Old 06-13-2011, 07:30 PM   #1869
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
I just broke 50 for the first time this weekend. Two round trips from Hilo across the summit of Kilauea and back, plus lots of noodling around the Kilauea summit and Ka'u Desert roads. About 50 stops (engine off/on) during that noodling, as well. (150 miles total) :D
bkrownd is offline   Reply With Quote
Old 06-15-2011, 07:27 PM   #1870
matthewai
matthewai's Avatar
Drives: it is kinda stock
for an auto transmish will putting the car into neutral and coasting to a stop save a little gas ive always done this maybe not all the time but most of the time (i havent searched anything on this so i dont know)
Old 06-16-2011, 02:55 AM   #1871
bkrownd
bkrownd's Avatar
If you know what you're doing it can save fuel in the right situations, but rolling in neutral with an automatic transmission could potentially also put you in trouble if the engine stalls while you're coasting. More of a problem with a heavy SUV (been there, done that) than a Yaris, but it's something to keep in mind.
Old 06-16-2011, 11:19 AM   #1872
malibuguy
Obsessed with 1.5L
when your in neutral you don't get fuel cut off
-96 Tercel 4dr
