Amp with Stock Head?
I am thinking about adding a sub and replacing the speakers but i don't want to add an aftermarket head, Is it possible to amp the stock head? would splitting from the current speaker wires to the amp then back to the speakers work? I have a sony head unit but all the kits available in canada for the dash look like crap.
wa do dem
you can use a line out to power the subs but to power the component speakers you cant unless you run the signal to the amp and then back to the speakers and you should use an amp for the subs and one for the speakers if you do that just amp the subs useing a line out and replace the speakers it will sound good but not as good as amped speakers with a aftermarket head unit
What colour is the line out wire that i will need to tap into?
wa do dem
well the easy way is just use the back speaker on either side use both negs and pos togather from one speaker brb with pics for you
wa do dem
![]() ![]() see like that
wa do dem
wa do dem
wa do dem
both negs- to brown both pos+ to yellow on the drivers side
Awesome, I have a project to work on this weekend. Thanks for your help!
![]() Drives: yaris Join Date: May 2007
can you show me how to get to the head unit and where to hook up line out converter. Very new to this stuff?
wa do dem
why when you can just do it in five minutes the way i have it in the pics and it works just as good
![]() ![]() Drives: 1.8 3dr Yaris TS Join Date: Nov 2008
How did you guys took the wires from the head unit to the amp and then to the speakers. I am thinking of adding 4 new speakers and a sub with an amp to the stock head unit, since I have a TS and don't want to replace the HU.
| 2007 stock head unit dims out | antfeldsch | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 06-15-2007 09:12 AM |
| Stock Head Unit + watts | naossoan | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-25-2007 09:00 PM |
| small 4ch amp. 4x100rms | ben dover | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 04-08-2007 04:17 PM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
| Stock Head Unit from '07 Sedan | Venom | Items for Sale by private party | 5 | 01-19-2007 08:27 PM |
