Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 06-12-2011, 12:04 AM   #739
gosuyaris
gosuyaris's Avatar
Drives: Yaris 2010
Send a message via Yahoo to gosuyaris
Originally Posted by rickyml View Post
tol, yung superblack mo sa windshield sa labas mo ba idinikit or sa labas?
Tol, sa labas ko pinalagay un kc bka masira ung clear tint ko... Sa loob kc nklagay un..
gosuyaris@0558478124
gosuyaris is offline   Reply With Quote
Old 06-12-2011, 12:25 AM   #740
rickyml
rickyml's Avatar
Drives: Yaris 2008
di ba sya nadadali ng wiper?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 06-12-2011, 01:18 AM   #741
syntax
syntax's Avatar
Nup... Iba tlaga ung dating tol... ramdam ko tlga ung prang sinasakal ung makina lalo pg ngshift ako ng gear prang biglang preno pg inapakan ko ulit ung accelerator? Tapos khit bombahan mo siya wlang nilalabas na pwersa... Cge tol pg my time ipatest ko syo.. Tnx..
balik mo kaya ung stock intake pre,para macheck talaga kung ung ang dahilan...
Old 06-12-2011, 02:51 AM   #742
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Tol gosu, mukhang alam ko yung sinasabi mo. Kasi after nung paint job sa intake housing nung binalik ko na tapos pauwi, naramdaman ko nga na parang nanibago yung makina, naramdaman ko rin yung parang nagppreno habang nagkakambyo. Pero nawala din nung malapit na ako sa bahay hanggang ngaun parang normal na ulit. Hindi kaya may singaw yung setup mo o kaya naninibago pa talaga yung engine mo. baka kailangan ng konting laki pa ng pipe sa gamit mong pipe ngaun.
rye7jen is offline   Reply With Quote
Old 06-12-2011, 04:01 AM   #743
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
+1
mike, balik mo muna yung stock intake, ma-isolate lang natin kung saan ang problema. Duon lang yan sa palagay ko, need that special T pipe otherwise jigsaw katapat nyan. Try mo lang tol.
jonimac is offline   Reply With Quote
Old 06-12-2011, 06:45 AM   #744
gosuyaris
gosuyaris's Avatar
Drives: Yaris 2010
Originally Posted by jonimac View Post
+1
Mga tol, nasubukan ko na ibalik ung stock intake pero gnun pa rin... Kya binalik ko ulit ung bago and naisip ko nga baka sa exaust pipe ko.. Posible rin n bka ngaadjust p ung ECU ko sa bagong intake gaya ng sabi ni syntax.. Obserbahan ko muna until weekend.. Pg d ngbago need ko na ipacheck sa redcap or sa toyota... Bahala na..
Old 06-12-2011, 07:05 AM   #745
syntax
syntax's Avatar
try mo nga ibirit ng ibirit si gosu, un bang nasa 100+kph ng mga at least 15 - 20 mins, then obserbahan mo ulit
note: pero wag sa 70kph or 80kph na lugar ha, dadami ang pictures ni gosu, sa ringroad 120kph ang kalsada na yan...
Old 06-12-2011, 11:27 AM   #746
zsazsa zaturnnah
zsazsa zaturnnah's Avatar
Drives: 2010 Yaris YX
Mga kayaris baka meron kayng idea kung bkit gnun nangyari ky gosu nung pinalitan ko ng intake and exaust... Nilinisan ko na rin ung intake sensor and nareset ko n ung ECU pero gnun p rin.. Any ideas?
ECU? nireset? nino? Ang alam ko kasi ang ECU sa casa lang ginagalaw!
zsazsa zaturnnah is offline   Reply With Quote
Old 06-12-2011, 01:43 PM   #747
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
mamang ang alam ko basta tinaggal mo both - at + terminal ng battery magrereset na ung ECU mga tol need ng ayuda
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 06-12-2011, 01:58 PM   #748
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
yan din ang aking palagay....
rosco is offline   Reply With Quote
Old 06-12-2011, 02:36 PM   #749
gosuyaris
gosuyaris's Avatar
Drives: Yaris 2010
Mga tol krarating lng namin ni gosu.. Sinubukan ko siya ihirit ppunta jadid sanaiya... Ok naman pg nasa hi-way... Tumakbo siya ng 150kph tas kaya pa ihirit.. Ntakot lng me kc dami truck sa daan... Napansin ko lng is pg mbagal takbo ko prang hirap siya ihirit ng mabilisan d ktulad nung dati.. Ung arangkada niya ung bumaba pero pg nkbwelo na inaabot din niya ung peak.. Sa palagay ko tlgang kelangan palitan ung t pipe ko kc bka kulang ung nahihigop na hangin nung intake ko since mdyo my kaliitan siya compared nung kina pilyo and tol rosco... Tol pilyo need your help ulit para sa t pipe... Tnx in advance ulit tol...
Old 06-12-2011, 02:52 PM   #750
syntax
syntax's Avatar
hhmmnn... ano ang RPM mo nung nag 150Kph ka? tapos nung sinasabi mo na parang sakal sya ano ang napapansin mo na RPM ni gosu?
Old 06-12-2011, 02:53 PM   #751
syntax
syntax's Avatar
yan din po ang pagkakaalam ko.....
Old 06-12-2011, 02:58 PM   #752
gosuyaris
gosuyaris's Avatar
Drives: Yaris 2010
Inaabot siya syempre tol pero d nman siya bsta2 nasisira.. Bsta mganda pgkadikit mo.. Make sure na wala bubbles... besides mdalang lng nman gmitin wiper d2 d tulad sa pinas...
Old 06-12-2011, 03:02 PM   #753
gosuyaris
gosuyaris's Avatar
Drives: Yaris 2010
Nglaru sa 4k-4.5k ung rpm tol... Tas pg mbgal d ko pa nccheck..
Old 06-12-2011, 03:09 PM   #754
syntax
syntax's Avatar
ok pre ang rpm range na yan kapag nasa 4K-4.5K, which means malakas ang pasok ng air sa intake mo, kapag sa tingin mo ay mataas ang rpm pagmabagal, sa palagay ko ay hindi akma ang diameter ng T bracket para sa MAF at air filter, or may konting singaw sya, dahil nawawalan ka ng torque ( para sa arangkada)
Old 06-12-2011, 03:22 PM   #755
gosuyaris
gosuyaris's Avatar
Drives: Yaris 2010
Un na nga tol eh kaya last choice ko is plitan muna ung T pipe kc nga iba ung naikabit ko sa ginamit nina tol rosco... Mas maliit ung diameter niya kya cguro hirap siya... Let's see pg same2 na ung gamit namin.. Pg ganun pa rin, then there must be something wrong na nangyari ky gosu during installation nung exaust and intake... Bka napasokan ng dirt ung fuel injector ko..
Old 06-13-2011, 01:54 AM   #756
syntax
syntax's Avatar
don't worry pre' makakatulong ang mga kayaris dyan...
