Old 06-27-2011, 02:06 PM   #19
Kiteless
Kiteless's Avatar
Drives: US 2007 Yaris Liftback 5MT
Originally Posted by localkineguy View Post
It'll just be a standard blue two door hatchback...no frills, not even power windows/locks. This has got to get me through graduate school :P
Sounds like mine. I got my car brand new back in July of 2006. It had something like 3 miles on it. I was looking for a Yaris but no one had them and so I settled for a Scion xA. I got to the dealer and it had been sold. I thanked them, turned around and started walking to the door. The sales manager stopped me and wanted to know if I would want "one of those new Yaris cars they just got in" almost an hour ago. I went to look at them and they had not even peeled the plastic off the paint yet. I had to wait like 20 min for them to take all the plastic off the interior and exterior, I took it for a test drive and fell in love. I BARELY got financed, and the car has never failed me. It also had no options on it at all. Not even a stereo, just a plastic plate with a Toyota logo on it. I had to wait for almost 6 months before Metra came out with a dash kit on it. Found the kit on eBay weeeeeeeks before any local car audio places could get them.
Anyway, I am sure you will love your Yaris. Especially if you got the manual. Its the little car that just wants you to love it.
- Jason
2007 Toyota Yaris Liftback Base 5 Speed.
Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust.
Kiteless is offline   Reply With Quote
Old 06-27-2011, 07:27 PM   #20
nemelek
DWEED
nemelek's Avatar
You think that if the guy didn't do regular oil changes that's a deal-breaker?
It is for me.
Old 06-28-2011, 11:54 AM   #21
tk1971
tk1971's Avatar
Test drive it and make sure the clutch is in good shape.
Also, check the tires for feathering and uneven wear. You don't want to get new tires shortly after buying the car.
Good luck.
tk1971 is offline   Reply With Quote
Old 06-28-2011, 12:30 PM   #22
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Ask where most of the miles were made. It matters for the engine and for the tranny/clutch. Who was the primary driver? Kid who liked to push it or commuter's A to B car?
I used to wonder why it mattered where the miles were made. I then realized that highway miles means less wear and tear, especially for the tranny.
Old 06-28-2011, 05:19 PM   #23
localkineguy
Drives: 2003 Mazda Protege5
Tires looked good when I took a look at them...they looked evenly worn too. The owner/driver is a manager (late 30s?) at a Harley Davidson store. Many miles were highway (so he claims) to commute to and from where he used to work.
How can you make sure the clutch is "in good shape" via a test drive?
localkineguy is offline   Reply With Quote
Old 06-28-2011, 07:04 PM   #24
nemelek
DWEED
nemelek's Avatar
[QUOTEHow can you make sure the clutch is "in good shape" via a test drive?[/QUOTE]
Stop the car. Set the park brake. Put it in 5th gear. Rev the engine to red line. Pop the clutch while keeping the engine reved.
If the engine dies, the clutch is good.
If the engine keeps running, the clutch is bad.
Note: Don't let the current owner see you do this test.
Old 06-28-2011, 07:19 PM   #25
Kiteless
Kiteless's Avatar
For the clutch, I test by pushing the car hard in lower gears, with permission from the current owner of course. If you have been driving a stick you can feel the clutch slipping, but it's harder without a tach. Shift smoothly and apply power as soon as you let the clutch out. Don't do quick shifts and drive it like a race car, 1st gear, RPM's up, clutch in and wait a moment for the revs to come back down and second... it should be smooth. Don't forget to look at the dryness of hoses, and the state of the accessory belt. That belt runs your water pump among other things, so its important it does not break. Look at how cracked it is mainly on the inside that has ribbing that grabs around the pulleys.
Also test brakes, does it stop well? Good, no need to slam on them. Also brake gently, any wobble? If there is there may be a warped rotor and at that age will need replacing.
Look under the car, any oil?
After it's warmed up listen to it idle, it should be niiiiice and smooth.
Pop the air cleaner and look at it. Is it nasty? Even if it does not need it, maybe go get a test only smog done on it. If it passes, that is also a good indication that it is a solid running car.
You can even put a volt meter on the alternator and see what its putting out. I believe a good strong alternator should put out like 14 volts? May need correction there.
Thats my way anyway. I am too chicken***t to redline a car, especially someone elses. Hope this helps.
- Jason
Old 06-28-2011, 09:36 PM   #26
localkineguy
alternator voltage
1. Can you post a picture of the accessory belt? Is it the belt on the passenger side of the car?
2. Rotor warping shows up as vibrations in the brake pedal during deceleration right? (i.e. wobble = vibrating/pulsing?)
3. Can you also post a picture of the air filter?
4. Can I get a second opinion on the alternator voltage? I do have a multimeter and can do that pretty quickly
By the way, thanks for all of the responses guys
Looking at buying a 2003 Yaris TonyBee UK 8 03-31-2011 06:53 AM
Thinking about buying a 07 yaris sedan brg88tx New YARIS Purchase Forum 14 06-28-2010 11:57 AM
Buying Yaris stepish Australia 14 01-20-2009 10:11 AM
