#19 | |
![]() ![]() ![]() Drives: US 2007 Yaris Liftback 5MT Join Date: Aug 2006
Anyway, I am sure you will love your Yaris. Especially if you got the manual. Its the little car that just wants you to love it. - Jason
2007 Toyota Yaris Liftback Base 5 Speed. Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust. |
#20 |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
It is for me.
Making a decision without following it with an action is still a fantasy. |
#21 |
![]() ![]() ![]() Drives: 08 2Dr LB Base, Silver Join Date: Jan 2011
Test drive it and make sure the clutch is in good shape.
Also, check the tires for feathering and uneven wear. You don't want to get new tires shortly after buying the car. Good luck. |
#22 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Ask where most of the miles were made. It matters for the engine and for the tranny/clutch. Who was the primary driver? Kid who liked to push it or commuter's A to B car?
I used to wonder why it mattered where the miles were made. I then realized that highway miles means less wear and tear, especially for the tranny.
#23 |
![]() Drives: 2003 Mazda Protege5 Join Date: Jun 2011
Tires looked good when I took a look at them...they looked evenly worn too. The owner/driver is a manager (late 30s?) at a Harley Davidson store. Many miles were highway (so he claims) to commute to and from where he used to work.
How can you make sure the clutch is "in good shape" via a test drive? |
#24 |
DWEED
[QUOTEHow can you make sure the clutch is "in good shape" via a test drive?[/QUOTE]
Stop the car. Set the park brake. Put it in 5th gear. Rev the engine to red line. Pop the clutch while keeping the engine reved. If the engine dies, the clutch is good. If the engine keeps running, the clutch is bad. Note: Don't let the current owner see you do this test.
Making a decision without following it with an action is still a fantasy. Last edited by nemelek; 06-28-2011 at 07:51 PM. |
#25 | |
Also test brakes, does it stop well? Good, no need to slam on them. Also brake gently, any wobble? If there is there may be a warped rotor and at that age will need replacing. Look under the car, any oil? After it's warmed up listen to it idle, it should be niiiiice and smooth. Pop the air cleaner and look at it. Is it nasty? Even if it does not need it, maybe go get a test only smog done on it. If it passes, that is also a good indication that it is a solid running car. You can even put a volt meter on the alternator and see what its putting out. I believe a good strong alternator should put out like 14 volts? May need correction there. Thats my way anyway. I am too chicken***t to redline a car, especially someone elses. Hope this helps. - Jason
#26 |
alternator voltage
1. Can you post a picture of the accessory belt? Is it the belt on the passenger side of the car?
2. Rotor warping shows up as vibrations in the brake pedal during deceleration right? (i.e. wobble = vibrating/pulsing?) 3. Can you also post a picture of the air filter? 4. Can I get a second opinion on the alternator voltage? I do have a multimeter and can do that pretty quickly By the way, thanks for all of the responses guys |
| Looking at buying a 2003 Yaris | TonyBee | UK | 8 | 03-31-2011 06:53 AM |
| Thinking about buying a 07 yaris sedan | brg88tx | New YARIS Purchase Forum | 14 | 06-28-2010 11:57 AM |
| Buying Yaris | stepish | Australia | 14 | 01-20-2009 10:11 AM |
