#19 | |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
Oh man, I didn't realize it was automatic. I feel your pain lol... Shifts are TERRIBLE with a turbo on an automatic that isn't factory. Honestly, I think putting in / changing the housing to get a higher CFM is only going to make the current problem worse. I don't know what the Echo is like, but I know with the Yaris I really have to let off the throttle and help the trans shift. And past 4-4.5k RPMs forget it lol.
As for forcing open loop... I did some research that I'll dig up and show you. However none of it was very promising and I quickly gave up when I saw how easy it was to tune in open loop. Your other option is an O2 skew - weren't you doing that? Ok, here were the ways to enter open loop: 1. TPS > 75% 2. Cold start until water temp > ? (Can't find the exact temperature) 3. DFCO One thought I also had: Quote:
The first idea that comes to mind for me is to create a circuit. Basically you would monitor tps and as soon as the tps is reached where boost begins building, have a switch throw automatically to drop water temp to the point of throwing open loop. I'm not sure how you would build such a circuit, but I'm pretty sure it's theoretically possible. That's enough rambling for one day.
#20 |
Couldn't you just split the TPS wire, sending it to both the ECU and the aftermarket management, and manipulate one signal so TPS is always > 75% to the management?
I'm not an engineer or knowledgeable about electronics, it just seems like an easy circuit to build to cheat the system.
#21 |
I don't think that would work. Here's why: If you manipulate the ECU side of the TPS circuit you'll be causing all sorts of problems. If you manipulate the FIC side of the circuit it still won't throw the car into open loop.
Oh and splitting the circuit would split the amperage as well. The ECU probably won't like that too much lol. |
#22 |
I know that if the ecu doesn't see the car warming up within a certain time it WILL through a code for thermostat failure. I know this because I've had it happen on our '03 Matrix XRS. So tricking the ECU into thinking it's staying cold or switching back and forth will only work for a while.
#23 | ||
as i posted in february http://www.yarisworld.com/forums/sho...2&postcount=18
#24 |
^ WOW. That makes perfect sense. The injectors will have the completely wrong duty cycle as a result, but that's where the piggyback comes in. I'm curious though - wouldn't the ECU see this as a circuit failure and immediately throw the car into fail safe? Even if not immediately, the same could happen after a few drive cycles.
#25 |
my friends have been using this on their boosted xrs's for at least 2 years w/o issue
#26 |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
my only concern with at is that with an auto will it downshift when that signal goes to 100%.
not sure how the auto works. |
#27 |
I'm starting to think this is the problem with making high RPM power. The ports for each cylinder are like 3/4 each max, to an opening for the turbo that's what, maybe 1.5".
#28 |
Awesome!
im wondering, if a dremel my help, or reduce flow.
im still leaning towards the mirco manifold and a t3 turbo .43ar. just think it may be overkill. hard to say. i cannot find a gt25 with the .6ar for under 500.. buy me suby spun a bearing and i think i need to start focusing on that for a while
#29 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Also, with your tuning issues ... the emanage should work just fine. Sounds like you pegged out your maf voltage.... anything over 5psi I would tune utilizing greddy pressure sensor, and clamp maf to 4.3v.
Ptuning.com |
#30 |
I just checked out your pics in your other thread, definately ditch that soft rubber 90 degree coupler on your turbo inlet. I have seen that very coupler colapse from the suction the turbo creates while boosting, claiming gobs of power. Even if you dont do a short intake , change that coupler to a rienforced 4 ply.
Ptuning.com |
#31 |
Awesome!
do you have any pics of your old setup? i already upgraded the inlet elbow, and dont know how to make the intake much shorter.
the emanage did nothing for us so we went with the fic already, still have the emanage laying around. the big problem is with the echo it tries to stay in closed loop as long as possible. ive seen it stay as long as 5000rpm. so tuning is a challange. what kind of top end did you get out of this turbo? full boost at 2200rpm and being able to flow air at 6000rpm isnt easy for most turbos on the market, my wrx has the same spool characteristics and ran out of flow at 5000rpm. i know im not maxing maf voltage yet, still only at 5psi. and im at 12:1 afr so its not a fueling issue. im interested in any information on your setup, pics, dynos, tuning. how you beat closed loop ect. Thanks. |
#32 |
As far as the intake , trimming of the rain gutter is required. It isnt hard though , as the whole thing unbolts (after removing wipers, wiper motor assembly ). This is the only picture I could find below. The filter is tucked under plastic cowling with a red hydrashield. The green lines ( solid is hp, dotted is torque) on the dyno graph represent the greddy kit maxed out with 3'' exhaust, water meth, and intercooler . It holds boost well to redline and still made power to there. It was 19 to 21 psi, cant remember exactly. Just as a reference point, 86whp is what a stock MT 1nzfe puts down on our dyno. 116whp is what the Greddy kit puts down out of the box with stock exhaust. 225whp is what a stock evo puts down.
Ptuning.com |
#33 | |
#34 |
The kit is set at 5 psi out of the box with no intercooler.
#35 |
ahh, coolbeans.. that makes sense then. thanks
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| FS: OEM Toyota Vios Turbo Kit | CTScott | Items for Sale by private party | 24 | 07-31-2011 09:12 AM |
| FS: Greddy Turbo Kit | Bluevitz-rs | Items for Sale by private party | 12 | 09-14-2010 05:27 PM |
| ))) bolt on greddy turbo kit ((( | aucorium | Performance Modifications | 5 | 02-14-2010 03:32 PM |
| Greddy Turbo Kit | Giupo | Items for Sale by private party | 17 | 06-16-2009 05:14 PM |
