Old 08-01-2011, 08:45 AM   #19
JackeWisth
Drives: Toyota
thank u. all very clear now.
md toyota
JackeWisth is offline   Reply With Quote
Old 04-18-2012, 03:57 AM   #20
aprilia
Drives: Yaris I
Hello,
I am from Germany.
I would like to know where you got the service manual for the 1st gen yaris from?
You posted a part of it here
http://www.yarisworld.com/forums/showthread.php?t=29617
I would like to have it too.
Greetings
Benjamin
aprilia is offline   Reply With Quote
Old 11-10-2014, 01:15 AM   #21
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
If pins are rusted and sealed, you can remove them following next steps. I will skip wheel removal and safety precautions.
1. Remove clips and connecting spring.
2. Release two 17mm bolts that hold caliper as one piece. Release them by
2mm. Use six angle spanner only.
3. Hammer them (17mm bolts) nice and easy. This way you will release nearer part of the
caliper as well as those pins. If nothing happens, remove those bolts
completely.
4. Again, nice and easy, hammer nearest part of the calliper to release those sealed pins, and then remove
them using the puncher and hammer.
This worked for me each time.
Gagi is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
Where can I find rear brake pads (??) for a 2008 Yaris? MisterFreelance Canada 7 03-27-2010 06:45 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
