![]() Drives: 2008 yaris Join Date: Oct 2010
how loud do water pumps get when they fail?
and what kind of noise do they make? rattle, sqeek or grinding?
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
It usually starts with a squeak, then it becomes a louder grinding noise, and as the bearing goes, they begin to rattle due to the slop in the shaft. At that point you should see a fairly good coolant leak.
would you notice it if you spin it by hand?
![]() ![]() Drives: S sedan Join Date: May 2009
It definitely starts to rattle. You might not notice it when cruising on the road, but it is obvious when you're parked with your engine running. If you do change the water pump, remember to put in a new serpentine belt since it's same labor.
Check for thrown coolant on the underside of the hood. Possibly an indicator a long time before the pump packs it in.
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
When mine failed at 15K miles.
I didn't hear anything out of the ordinary. I did see the coolant spray from front to back on the inside hood and inside the water pumps pulley. |
here's my issue, posted in its owne thread... http://www.yarisworld.com/forums/showthread.php?t=34990
My girls 08 yaris has been making a racket from under the hood it Sounds like a knocking coming from the passenger side where the accessories are. Its stays constant at idle and when you raise the rpms. I Pulled the accessory belt off and the noise went away. Put it back on and it was back. Pulled out a stethoscope and tried to listen for anything out of the ordinary on the a/c, alt and water pump. Think I can hear the noise coming from the water pump. Every thing else sounded normal, but I can hear the rattle when I put the scope on the water pump near the pulley just not as loud. Any ideas? Will a water pump make that big of a racket? |
didn't notice any anti-freeze when i looked at it, but will check again
Yes. When it gets bad it's pretty noisy. You need to replace it. Get a non-Toyota aftermarket brand. Check some of the other water pump threads for recommendations on which to choose.
Not quite a noob
Some of the aftermarket ones are so cheap it's suspicious though, but they do however LOOK sturdier
just found this on youtube...
http://www.youtube.com/watch?v=M_ggV2MSxTM ... sounds just like my girls ride. |
Wow another close yaris owner. Live in Fayetteville also and had my pump go out. Noticed long before it got serious by the spray sign under the hood. Easy change at my shop. Give a holler if you need assistance.
What is the drill to loosen the suspension and drop the engine so you can get the wp in and out? Is that what you do drop the engine?
Or is it something else? Or is there a way without dropping it? Thanks! |
toyota
easiest way is to check the inner side of the pulley you should see pink stuff if its busted cause by leak
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
got it done this morning. didn't see alot of pink until i pulled the a/c pump, but the bay is so dirty it was easy to over look the spray/dirt on the hood. i didn't have to drop the motor, just slide it back about 1/2" using a breaker bar btween the mount and head. didn't need to use any force it moved real easy. got all the parts from napa, in stock and could have done the hole job from the hood without getting under the car if not for the lower bolt and running the new belt.
Good job c-dub. Glad you got it sorted out!
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
I'm not sure what year Toyota started the 5 year/60K powertrain warranty, but water pumps are covered. It says this in the 2010 warranty book I have.
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| fail fail fail | thebarber | Off-topic / Other Cars / Everything else Discussions | 10 | 05-20-2011 10:29 AM |
| 07' HB Water Accumulation in hatch | bobolinko | General Yaris / Vitz Discussion | 9 | 09-26-2010 02:55 AM |
| Wine of Water | Benggolf2 | Off-topic / Other Cars / Everything else Discussions | 4 | 12-25-2009 02:01 PM |
| water in the tails? | the_boss | Cosmetic Modifications (Exterior/Interior) | 9 | 02-20-2009 12:53 PM |
