![]() ![]() Drives: Yaris Hatchback 2012 SE Join Date: Aug 2011
A/C PROBLEM
Hi guys I buyed a yaris HB 2008 last week with 29000 miles on it, I noticed that after driving like 30 to 40 minutes the a/c stops blowing cold air and blow cool air. I have to turn it off and wait like 5 minutes and then it starts to work again...anybody know what it could be?
thanx |
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
Sounds to me like you are a little low on Freon. Small can from an auto parts store would do fine for you. it is not hard if you get the one with a gauge with it... just fill till the upper part of the green and do not go into the red zone. It'll work all good again. |
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
Sounds like one of your lines are icing up, had a similar situation with suzuki van. When I checked, the line was iced up then I would turn off AC. Once the ice melted from the heat, AC would be good again.
It's possible the condenser is icing up after long use. Are you blasting it at full speed for 30-40 min? There also might be a clog in the drain line.
#5 | |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| A/C sometimes won't start? | Greedo51 | DIY / Maintenance / Service | 5 | 07-23-2016 08:50 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
