Old 08-17-2011, 11:43 PM   #1
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Wheel spin
I feel that I have excessive wheel spin going uphill and on some corner exits. I have Tien SS coilovers that are adjustable set to full hard. Tire pressure in the front is set to 36 to 38 psi hot Dunlop Star Specs. Short of getting a LSD Is there anything that you can adjust to help this condition ??
soloecho2 is offline   Reply With Quote
Old 08-18-2011, 12:14 AM   #2
try a softer suspension setting... hard suspension might be making your wheels bounce and lose traction, a softer setting may be more compliant to the road surface and keep grip better. Same story with maybe a little less tire pressure
Old 08-24-2011, 12:12 AM   #3
soloecho2
soloecho2's Avatar
Softening the suspension seemed to have helped. But its still an issue that needs to be sorted out.
Old 08-24-2011, 09:51 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
stiffer rear springs or less front sway bar.
Old 08-24-2011, 12:28 PM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I get crazy wheel spin in slaloms and exiting turns... even with R comp tires.. i will take these tips in consideration next event.
Old 08-24-2011, 10:10 PM   #6
Viperoni
Drives: 2005 Toyota Echo
I also have wheelspin problems exiting any corner, even downhills, even on my Goodyear slicks (21.5x8x13), bone stock motor.
I agree with less front swaybar and stiffer rear springs, but mostly the front swaybar.
2006 Saturn Ion Redline
Old 08-24-2011, 10:20 PM   #7
ilikerice
ilikerice's Avatar
i've been meaning to pull my front sway bar off.. just havent gotten around to it being super hot lately
Old 08-24-2011, 10:57 PM   #8
Jason@SportsCar
The only fix is a good LSD, anything else is a band-aid that wont ever eliminate the problem.
In the meantime, as others have said, more rear spring and less front bar. If you have the front bar with the blue dot (24mm) try the purple bar (23mm), it helped our car rotate. http://www.yarisworld.com/forums/sho...&postcount=749 No front bar may help in sweepers and on corner exit, but the car will be slow in transitions and slaloms.
Old 08-24-2011, 11:19 PM   #9
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
One way adjustable coilovers have control over the rebound (expansion rate), not compression (90% of the time) . Setting it stiff in the front will cause your current situation to worsen. What everyone said is right on the money.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 08-25-2011, 12:02 AM   #10
johnny_vitz
Imagine how I feel LSD is in my future...and some good coilies
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 08-25-2011, 05:50 AM   #11
ilikerice
ilikerice's Avatar
thanks for that input.. I will look into this this weekend..
Old 08-25-2011, 01:18 PM   #12
+1
Old 08-25-2011, 02:04 PM   #13
johnny_vitz
+1
Actually, Garm, do you know if the LSD you sell will work in my 1st gen xb transmission?
Old 08-28-2011, 04:40 PM   #14
soloecho2
soloecho2's Avatar
Hey guys thanks for all the updates. I can't wait for Sept 18th to try them out. Garm like Johnny said do you have or can you get a LSD for the ECHO Trans. I know he needs one for the SCION.
Old 08-29-2011, 02:30 PM   #15
LSD should be cross-compatible between Yaris and 1st gen xB. It's listed as the same part number by Kaaz and others. I can get Kaaz, I can also source a TRD LSD if you want that. Or if you want the gold-plated version, get the OS Giken.
I would imagine the Echo shares the same parts too, but I cannot say with any certainty. Best to jump on the 'net and get some part numbers, or find someone who's done it.
Old 08-30-2011, 02:38 AM   #16
Bluevitz-rs
The Echo tranny uses a 6 bolt diff. The xB I'm pretty sure uses an 8 bolt .
Old 08-30-2011, 02:54 AM   #17
^ Yep, 8 bolt.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
