#19 |
Mr. 155 and climbing
1,000,000,000 pounds!
![]() internal wastegate is set to 6~7 lbs.
#20 |
how much was the kit and did it come with everything you needed? i have seen kits for roughly $1600 but it says it does not come with management so i figure the cost to be significantly higher after you get everything you need.
I know you said you were going to wait and get all the details before you say what you paid but was just curious what your "kit" cost and if it came with at least most of the stuff. I spent way too much time at work looking at your photo gallery. it is a good clean install. looks really nice. |
#21 |
^ Carlos would be the one to ask about the price of the kit. I did some upgrades so I honestly cannot recall what the base price was. Additional stuff done was the FIC, powder and ceramic coating, gauges, boomslang, exhaust...I think that was over and above the kit however the kit comes with everything else really. The piping, turbo, hoses, high quality clamps, BOV, injectors, fittings, high flow downpipe, etc were all in the kit. His kit is similar to the Zage in that it gives you what would be the essentials and you pick up the "custom" stuff that you would want to go with it al a carte.
In regards to the install, thanks. Carlos did most of the work with assists from myself and my buddy John. He was professional and knowledgeable.
#22 |
Well for those of you that don't know I have had issues since the install when attempting to use the FIC. I was finally able to get down to visit with CTScott and leave my car with him for the week. He has found a couple possible issues with my Boomslang harness which he is going to address so I am keeping my fingers crossed that I will actually be able to use the setup as it should be used. Since install I have been bypassing the FIC and using the stock ECU 100%. As long as boosting with WOT it has been great and dumping fuel as it should however if feathering the throttle the car will run lean. Not super lean, but lean nonetheless. I still have no regrets buying the custom kit from Carlos (Turbo_Yaris) as it has been solid and pretty much been able to leave it to run. I am not sure what the folks over at Boomslang are doing or whether or not there have been others that have had messed up harnesses? If this doesn't resolve my issue then the next step will be to approach AEM about replacing the FIC.
#23 | |
#24 | |
The answer to that would be no at this time however with the modifications that Scott will be making I am hoping for an answer in the next 24-48 hrs. We did shoot Brian an email to have him look at his harness since his was built and purchased at the same time as mine. I am awaiting a response from his as well.
#25 |
That will be very helpful. I have two on the shelf and need to know if they should go back to Boomslang for modification.
#26 |
Will let you know for sure. I could have shipped mine back to Boomslang, but then the car would be off the road and I can't afford that. Also I have no issue with trusting Scott. He has been an immense help with all of my electrical questions over the last year.
#27 |
Tonight I will be modifying the harness, so we'll have the answer. The issue that I found with it last night is that the MAF (VG) signal and the Crank position sensor (NE-) signal are supposed to be "intercepts" rather than "taps" as they are wired on the boomslang. As-is. the F/IC can only read, and not override the MAF and Crank signals to the ECM.
#28 |
I'm hoping to get my F/IC back from AEM this week. Everything was working perfectly with my Boomslang and F/IC except for the starting issue. Did Carlos modify your Boomslang at all?
#29 |
If I recall correctly he only removed a couple resistors because the harness was designed for the 1nz for the scions and not the Yaris...but I could be recollecting wrong.
#30 |
I didn't see any signs that it has been modified.
#31 |
^ interesting. I remember Carlos posting that these harnesses were made for the Yaris, but maybe that was after that first one was made. My memory isn't that good.
#32 |
I am trying to tecall conversations he said he had with boomslang but we discussed so much it is foggy.
#33 |
I contacted Boomslang before I bought the harness and they said it was made for the Yaris. Is there anyone else besides the 3 or 4 known users that are actually using the harness?
#34 | ||
#35 | |
On Adrien's Boomslang: CPS (NE+) is orange/black input, orange/white output MAF (VG) is white input, no output. CPS (NE-) is yellow/black input, no output. Both of these signals should be intercepts, per AEM.
#36 |
got pics? otherwise, it's a word game.
Further, Adrian's harness may not be the production piece they make now. That is still in question.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| HKS turbo for mk1 yaris 1 litre 1SZ-FE | nuttallacpw | Items for Sale by private party | 10 | 01-26-2011 05:03 PM |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
