Old 10-01-2011, 05:28 PM   #1
bankrobber
Drives: 2007 Yaris Hatchback
GL-4 or GL-5
Having grinding when shifting want to change oil. Not sure what to use. I been using supertech brand synthetic blend from walmart. No problems till now at 120k miles. Hope I didn't put in wrong oil. What brand or GL do I need
bankrobber is offline   Reply With Quote
Old 10-01-2011, 06:20 PM   #2
bankrobber
Crap the oil I have been using is GL-5. Have I hurt the synchro to cause the grinding?
Gonna go get some Royal Purple that says compadable with GL-4 and 5
Old 10-02-2011, 12:46 AM   #3
Hershey
GL-4 is better . Go here for details , http://www.yarisworld.com/forums/sho...?t=8912&page=5 . Might want to read some other pages as well .
Old 10-05-2011, 07:45 AM   #4
bronsin
bronsin's Avatar
The oil you have been using is fine. Purple oil will not fix the problem. (now if only they made yellow oil) If it was my car I would start by bleeding/changing the oil in the hydralic clutch.
Old 10-05-2011, 11:56 PM   #5
Hershey
GL-4 is best . Know this from experience with a '08 3 door YARIS and a 2000 Chevy Prizm ( Corolla ) . Both 5 speed manuals . Tried MOBIL 1 ( GL-5 ) in the Prizm and the shifting would grind , etc.. Drained that for REDLINE MT-90 a GL-4 ( 75w-90 ) and no more grinding , notchiness or clunking into reverse . Live and learn .
Old 10-06-2011, 01:18 AM   #6
Viperoni
Drives: 2005 Toyota Echo
If it grinds every gear, it probably isn't the tranny fluid.
I also used Redline MT-4 in my Echo and it worked well, instantly noticed smoother shifting.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 10-06-2011, 05:52 PM   #7
bankrobber
Only grinds if I try to mash clutch and put in gear say all within 1.5 seconds
Old 10-07-2011, 01:15 AM   #8
Viperoni
Something's up then, I flat foot shift when racing sometimes and I don't get any grinding.
