Old 03-08-2007, 01:09 PM   #37
sqcomp
Roadrunner Jr.
sqcomp's Avatar
FYI, those non-foulers should only be $5-$10 for two of them.
― Thomas Paine
Old 03-08-2007, 02:27 PM   #38
ToTo
ToTo's Avatar
Drives: Toyota Yaris T SPORT
How about in the case of a high flow cat and sensors, one before the cat in the manifold and one after the cat, instead of in a straight pipe?
ToTo is offline   Reply With Quote
Old 03-08-2007, 04:26 PM   #39
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
Apparently since I'm a ZPI hater (not really) you might not want to try this little trick I learned from my SRT-4 days...
Toto- I believe I know why you're going to see a code if you just install on a straight pipe. Read on...
When I replaced my o2 pipe and my downpipe, we had two o2 sensors. One on the o2 pipe itself and one in the "cat" area. I decided to run a straight downpipe with a cutout. I understood that the computers would throw a code if the o2 sensors didn't detect a certain temperature difference between the two sensors. What I did was to buy a spark plug non-fouler, bore the inside out a little bit with a 1/2" drill bit. Why? Well, go ahead and try to screw in an o2 sensor to an 18mm non-fouler without boring the inside top out a little bit, you'll understand...the sensor just doesn't fit. When you take a bit of material out of it it will screw right on. After you bore that non-fouler out and fit it onto the o2 sensor, simply screw the non-fouler into the downstream sensor bung.
This backs the sensor off just enough to have it read a lower temperature like you'd have with a cat...like you're supposed to. It is my belief that when you look at a catalitic converter versus a straight pipe, you should notice that the o2 sensor dosn't go straight into the pipe's exaust stream as much as it would with a straight pipe. With my limited smarts on vehicle engines, I believe the temperature issue is why you'd see a code.
Now, I can find the how to for the SRT but it is really as simple as i've described it. I don't know the specific size of the stock o2 sensor on our Yaris. Sice I'm NOT going to be messing with the engine of mine...I leave this up to you guys.
On the old car, I NEVER threw a code with this little DIY mod in the year and a half I used it.
Thoughts?
This is exactly what I was talking about in my post. It's worked for me on several cars. I coined the term "Ghetto Sim" on thevboard for this mod.
Dragonacc is offline   Reply With Quote
Old 03-08-2007, 05:55 PM   #40
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Uh oh! This one might be for real! This is a super cheap way to "beat" the system. It's worth a try.
― Thomas Paine
Old 03-09-2007, 11:58 AM   #41
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Originally Posted by CASTREX View Post
So, any one thinks that could be possible to open the OEM muffler and take some guts out of it? I dunno how that muffler looks on the inside, but anyone thinks that this could be done? Improved flow and quite at the same time!
I've been thinking of trying this myself. I'll let you know how it goes. Probably wont get to it for about a month though.
Galavoxx is offline   Reply With Quote
Old 03-09-2007, 02:23 PM   #42
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Maybe one of the guys running the TRD's or one of the other aftermaket mufflers would be willing to open up theirs OEM so we can take a look and see if is worth it.
You could post it on the TRD muffler thread and see if anyone answers back.
Old 03-09-2007, 02:58 PM   #43
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I already have the OEM muffler. I just need to get over to my buddy's house. He has the welding equipment.
Old 03-09-2007, 03:07 PM   #44
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
Originally Posted by Nimble View Post
Right, guys like you...you know car salesman....typical douche bags.
if thats a crack on my job title i got news for you WRONG DEPARTMENT.......
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 03-09-2007, 03:08 PM   #45
CASTREX
CASTREX's Avatar
Good...! make sure to take a lot of pics
Old 03-09-2007, 03:42 PM   #46
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
Right, you work for the ricer part sales dept, you know, based on your "mod" list.
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline   Reply With Quote
Old 03-10-2007, 09:58 AM   #47
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
i said this before in another thread and i'll say it again, EVERYTHING on my "MOD" list was cost or free so WHY NOT.....
Old 03-12-2007, 09:31 PM   #48
WRLEO
Drives: Yaris
Were working on a Header that actually makes power right now..
Be patient.. We should have them done very soon here.
WRLEO is offline   Reply With Quote
Old 03-12-2007, 09:36 PM   #49
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
NEWS FLASH!!! A Yaris is slow even with a header, pulley, intake, exhaust, lightweight oil filter cap, high performance windshield washer fluid tank, color matched badges, less than 1/2 a tank of gas, and you cutting your legs off to save weight.
don't forget mudflaps and power windows and doors i've by dorpping those in you get great hp
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
My Yaris IS SLOW David81 Performance Modifications 47 08-08-2006 02:34 PM
