![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
Will switch rated 15 amps/120 volts AC withstand 15 amps DC?
Will a switch that is rated for up to 15 amps/120 volts AC withstand 15 amps DC?
Thanks, R. |
A switch should be OK. AC only rated relay contacts don't do well with high current DC, but switches are typically fine.
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
