Old 11-01-2011, 06:56 PM   #1
DuckHunt
Drives: 2007 & 2008 Yaris Sedans
Rear Defroster Issue
I have a 2008 Yaris sedan. I noticed this week that the rear defroster is not working. The light comes on when you push it in and I can hear a relay click under the dash as if everything is working but it isn't heating. The fuse under the dash is good. Though there isn't one under the hood labeled for it, I confirmed there are none blown there either.
Based on a recommendation on another post, I check the voltage across the terminals on the back glass. I get nothing. I wanted to try to take off the trim panel, but I figured I would ask if there is a trick to it before I break something.
Any suggestions? Comments?
DuckHunt is offline   Reply With Quote
Old 11-01-2011, 09:55 PM   #2
thepartsmancometh
Drives: '08 LB, '07 WRX
might have a break in the circuit somewhere on the glass itself. never tried on a yaris, but on fords we have some goop (like nail polish) that you can paint on to fix the break.
thepartsmancometh is offline   Reply With Quote
Old 11-02-2011, 09:34 AM   #3
Lil Abner
Drives: 2009 3dr LB Manual
Just in case, maybe try swapping the fuse with a different one? SOMETIMES, it works. Fingers crossed it's that simple. Otherwise, I'd say start tracing the wires. Maybe find that relay and confirm there is power coming out of it?
Old 11-02-2011, 01:11 PM   #4
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
did you check the obvious - is the window grid plugged in? had that on a brand new chevy once, the connector was just hanging there.
the window lines are easy to damage, but it's also easy to test and repair.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 05:48 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 06:02 PM
