Old 11-01-2011, 08:41 AM   #19
randeez
Drives: 2008 3dr
Good, I got time to order more before it all gets shipped
randeez is offline   Reply With Quote
Old 11-02-2011, 07:12 PM   #20
MUSKOKA800
MUSKOKA800's Avatar
Originally Posted by randeez View Post
just got a 2008 3dr base model, 5speed. wasn't planning on mods to it, being primarily my work vehicle, but it feels like it's all over the road at 70+mph. how far am i going to have to go to get this thing to feel nice n stable on the highway? was probably going to start with the rear swaybar then springs and shocks if needed.
Adding a rear anti-sway bar (before all the other mod's) made a world of improvement in highway stability when experiencing cross winds and truck wake. Make an anti-sway bar step one in your quest for relief.
Old 11-02-2011, 10:01 PM   #21
randeez
Drives: 2008 3dr
yup thanks muskoka, i probably would have been good enough with just the sway bar- but garm's a hell of a salesman, i ordered the eibach springs also
Old 11-03-2011, 10:16 AM   #22
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
all this talk about a rear sway bar is really making me want to get one from garm as well. I'll have to keep my eye on his shop page. I'm finally going to install my nf210's (which is only an inch drop) on sunday. probably too late to get a sway here by then anyway. Maybe I'll ask Santa for a RSB. :)
Old 11-03-2011, 12:32 PM   #23
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
You should. Every Yaris should get the rear sway bar - it's a shame it's not standard equipment.
Old 11-03-2011, 01:12 PM   #24
randeez
Drives: 2008 3dr
Container came into port today, expecting Ultra Racing shipment delivered on Wednesday.
btw....it's thursday
lol
Old 11-03-2011, 01:14 PM   #25
^ and the shipment is "out for delivery" right now.
Old 11-03-2011, 04:28 PM   #26
A-Dingo-Ate-My-Baby
Drives: yaris
yup.
sway bar is absolutely step 1.
it changed my stock marshmallow into a decent lil buggy.
no need for lowering or springs for me now...they do help...
but a swaybar does -so- much, and of all things you can do... it is
the simplest to install, you just have to do it first. then see if you
want to do more mods.
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 11-03-2011, 06:26 PM   #27
MUSKOKA800
MUSKOKA800's Avatar
It's much easier to install the rear springs without a swaybar restricting rear axle drop. But definitely add one later for full value handling.
Old 11-03-2011, 08:09 PM   #28
Hamster
Hamster's Avatar
Drives: 2009 5-Door Liftback
Aside from the rear sway bar correcting highway wander, I've noticed that when the highway curves, I no longer need to take my foot off the gas in order to slow down. I can drive at typical high speeds. That feeling that the car will tip over is pretty much gone. I bought the OEM rear sway bar from Sparks Toyota (by the way, the OEM rear sway bar is manufactured in the United States, which I think is fantastic). It's the only suspension mod on my car. The lowering springs sound tempting, and I can definitely afford it, but won't it greatly increase the chance of rock chips?
Hamster is offline   Reply With Quote
Old 11-09-2011, 12:46 PM   #29
randeez
Drives: 2008 3dr
expecting some packages today/tomm... i knew i shoulda called in sick
thanks garm!
Old 11-10-2011, 12:42 AM   #30
I'm such a bad influence.
Old 11-10-2011, 10:36 PM   #31
randeez
Drives: 2008 3dr
welp, didn't get home till kinda late, it was already dark. opened the box up checked it out. took a look at the diy section and saw how easy it was to install. went outside and threw it on in the dark lol. tires left on, didnt even jack it up- though it would have made it a lot easier. took me about 20 mins and that includes thinkin i put it on the wrong way. springs i gotta find/rent a spring compressor for the fronts.
Old 11-10-2011, 11:29 PM   #32
vten
or you can buy those spring bolts compressor for about $3-40 and keep it for a future use
Old 11-11-2011, 11:19 AM   #33
randeez
Drives: 2008 3dr
yea i'll figure it out i think my brother may have a set i can borrow...
i guess i was a little skeptical about the rear sway bar, seeing as it doesnt really connect to the body to help body roll. kinda wishing i had done the thicker 23mm bar knowing that it just stiffens up the rear axle i think the thicker bar would do the same thing, just better. do notice more stability for sure though, haven't had the chance to throw it into some corners but seems to do as advertised
Old 11-11-2011, 01:29 PM   #34
No sway bar does that, it's a suspension part. But -- the suspension connects to the frame, and the frame connects to the body.
It's function is to resist twisting, which transfers weight to the inside FRONT wheel, thereby reducing roll and increasing traction in corners.
Old 11-11-2011, 04:04 PM   #35
randeez
Drives: 2008 3dr
good thing i have some springs also then
Old 11-18-2011, 01:51 AM   #36
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
That's the same reason I wasn't ever interested in a rear sway bar for the Yaris; it doesn't attach directly to the chassis. I'm sure it does help by stiffening the rear torsion beam but it's not a true sway bar. I would rather save that money and put it towards a good set of coilovers.
Normal sway bars do attach directly to the frame, or in the case of a unibody vehicle, the body.
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
So I'm driving down the highway... ecnal General Yaris / Vitz Discussion 23 09-01-2009 06:22 PM
Help. Instability on highway ibizagti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-16-2009 07:37 AM
Considering Yaris vs. Elantra businezguy New YARIS Purchase Forum 69 06-21-2009 08:39 AM
Highway driving SuperYaris123 New YARIS Purchase Forum 15 05-08-2009 01:22 AM
