Need Clutch
Need to upgrade my clutch. Making about 210hp right now. Looking for ideas on what brands are good.
Clutchmasters is the only way to go. Even at Stage 4, it's nearly close to OEM pedal feel.
Exedy Stage 1 was way too stiff. I would go CM Stage 3, you won't regret it.
Maybe but it's kinda pricey. Almost double the cost exedy
act
or support local vendor
advocatus diaboli
I second the Clutch masters...you get what you pay for.
I'm running a stage III with the 9lb flywheel Garm sells...you won't be disappointed.
#6 | |
You know exedy doesnt suck. I am all for supporting the vendors as I do all the time. But when money is getting tight you have to look out for your needs first. In this case it's out of my price range.
#8 | |
just to be clear, here was the original request:
I'm glad you like to support vendors -- what brand would you like a quote on? ![]() Exedy CCI ACT other?
#9 | |
advocatus diaboli
Then why are you asking about it? Seems to me you have your heart set on Exedy...
Clutchmasters:
$369 shipped Stage 1 $479 shipped Stage 2/3/4 $409 shipped aluminum flywheel ACT are $489-$499 for all stages CCI: $379 shipped Stage 1/2/4/5 $489 shipped Stage 3 (segmented kevlar) $289 CCI Steel flywheel 9.5lbs $299 CCI steel flywheel 8.4 lbs Exedy $159 Stage 0 (OEM) $299 Stage 1 (organic) $379 Stage 2 (cerametalic) Spec $299 Stage 1 $389 Stage 2 $399 Stage 2+ $359 Stage 3 $499 Stage 3+ $359 Stage 4 $499 Stage 5 $389 Spec Aluminum flywheel Jun (+ some shipping!) $699 Stage 1 $640 Aluminum flywheel TRD Japan - (+ some shipping!) $550 Stage 1 $599 Flywheel
Considering your power level and budget I think Clutch Masters Stage 1 will work best for you.
Stage 3 is $110 more but keep in mind it also lasts 2-3 times longer on average which will save you money in the long term on clutches, flywheels, downtime and labor. |
#12 | |
advocatus diaboli
Bingo...which is why I went with it, to save time/money in the long run. Not to mention the clutch feels spectacular, I drive in bumper to bumper LA traffic almost every week. My average work commute is 250 miles.
#13 | |
I'll do that today for you, and thanks, I always appreciate the chance to earn your business.
We called both companies.
CM Stage 1 70% increase holding capacity Stock is 120-140 TQ and CM Stage 1 is 180 TQ Spec Stage 1 15% increase holding capacity Stock is 120-140 TQ and Spec Stage 1 is 150-160 TQ Both manufacturers recommended you go for a Stage 3/4. Remember, we don't know the exact torque you're making when discussing this. So this is our "official" disclaimer, that we recommend more than a Stage 1. (have to say it) Clutchmasters supply OEM toyota throwout bearing vs. Spec sometimes use aftermarket Clutchmasters use steel backed plate vs. Spec use steel "lined" plate Clutchmasters use standard sprung clutch vs. Spec use "double" sprung clutch which can sometimes cause stiffer pedal feel.
#16 | |
2ZR swap. DO IT! Ask how!
So for those of us that have not gone FI, is the CM overkill? I'm looking to upgrade my clutch and flywheel when I drop in my frankenstien transmission, but likely won't be going FI for some time.
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 01:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
