Old 11-22-2011, 03:22 PM   #73
A-Dingo-Ate-My-Baby
Drives: yaris
Originally Posted by Yury View Post
may ask why not buy the toyota blade? doesn't seem expensive and you can replace the just rubber after.
I was on a mission to buy bundles of blades as presents
for everyone (dropped 380 bucks) and I figured I would also
try a trico exact fit.
This is my time to test a new batch of blades
[Just got done testing Michelins, RainXbrand, and Tripledge last 3 years]
so I went with Trico NeoForm on my Yaris, Trico exact fit (not so exact) rear.
and AquaPel as a surface coating (RainX only on side and back windows)
PIAA silicones on my 4runner and OEM rear insert, with RainX
and Silblade silicone for my GF, and sister gets PIAA's, with RainX
these silicone blades are not cheap
and I do not want to test AquaPel with Silicone blades. I need to test
with old-school Trico blades to know what Aquapel really does or does not do
this winter
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 11-22-2011, 03:35 PM   #74
Still Learning
Drives: 07 Yaris 3Dr HB
Originally Posted by A-Dingo-Ate-My-Baby View Post
figured out the rear Trico exact fit problem:
The Trico exact-fit replica wiper blade housing is close, but not exactly the same
as the OEM. The length stop-to-stop is 3mm longer. The Trico insert has some
wiggle room side-to-side, allowing the far-end of the insert to float off the glass
when pressure is applied to the middle of the insert
I slid the Trico insert out of the Trico arm, installed the Toyota arm, and slid in the
Trico insert. The Toyota stop tabs touch the insert at both ends of the blade, and when
the arm is at rest position, the stops hold the insert and keep it from floating off the glass.
So, in the case of: should I get a new insert, or a whole new Trico exact fit assembly ?
say NO to Trico, or just get the insert.
Other companies may make a better OEM-fit blade housing, but Trico dropped the ball on this one.
I now have 100% rear wiper contact. crisis averted.
This is good info. Thanks.
Still Learning is offline   Reply With Quote
Old 11-22-2011, 04:16 PM   #75
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
"...housing, but Trico dropped the ball on this one."
wouldn't be the first time. same issue on my old car, the curvature of the rear glass was not matched by Trico (and other aftermarket brands). the only remedy was to use the factory backing (the metal insert) which was bent correctly to conform. same story on Yaris...the blades look almost the same but definitely are not the same.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 11-26-2011, 12:33 PM   #76
10 Francis
Drives: 2010 Yaris S HB
Any Toyota part number that has "YZZ" in it may be a "Toyota Genuine Part", but it's not a factory part. it's common for wipers, oil filters, cabin filters, and some other fast-moving parts. We (the dealership) sell these because they're less expensive for us, and for our customers, and they're still high-quality parts that are approved by Toyota. I'll post a list soon of wiper blade part numbers for Yari.
10 Francis is offline   Reply With Quote
Old 11-26-2011, 01:29 PM   #77
10 Francis
Toyota wiper blade part numbers
'06-'11 TCMC
Blades:
driver: 85222-YZZ18-TM (650mm ~25.6")
passenger: 85212-YZZ14-TM (350mm ~13.8")
the inserts for these blades cannot be replaced. the whole blade must be changed.
Inserts (for factory blades):
driver: 85214-YZZF1-TM
passenger: 85214-YZZF3-TM
TCMC does not offer blades or inserts for the rear (HB)
'06-'11 Factory
Blades
driver: 85222-47020
passenger: 85212-44032
rear: 85242-52040
Inserts
driver: 85214-44140
passenger: 85214-68011
rear: 85214-31010
Old 11-26-2011, 01:36 PM   #78
10 Francis
oh yeah...
'12 Factory
Blades
front: 85222-52210
rear: 85242-42030
Inserts
front: 85214-58030
rear: 85214-42040
I haven't seen any TCMC blades or inserts listed for the '12 (yet)
Old 11-27-2011, 07:26 AM   #79
jeff618
jeff618's Avatar
Drives: Mazda 3
Arrow
I must have lucked out with my trico rear blade...its not perfect, but its about the same as the factory. Irregardless I still love the neoforms on the front - the crappy weather in Wisconsin the last 3 days has proved that over and over to me. Happy Thanksgiving ya'll.
First Time Caller, Long Time Listener, Great Topic, Love The Show...Thanks For Taking My Call
jeff618 is offline   Reply With Quote
Old 12-02-2011, 08:29 PM   #80
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
this winter
You tried all those brands you listed over the last three years (is that how I should read that statement?)
If so, I take it none of them lived up to your expectations? Hence your high regard for trico?
Old 12-03-2011, 01:45 AM   #81
Perpetuous_Dreamer
Drives: Yaris 2007
A little advice: don't buy wiper blades from NAPA!!! They are the worst investment in my car I ever made. Threw them in garbage next day due to the loss of receipt and went back to Toyota's OEM ones.
Perpetuous_Dreamer is offline   Reply With Quote
Old 02-02-2012, 06:54 PM   #82
jeff618
jeff618's Avatar
Drives: Mazda 3
I've been trying to buy a new set of neoform beam blades for the front since my last post and the 14" passenger side has been out of stock nationally all fall and winter. I just got an email from wipers123 and they're back in stock. Just thought I'd share because its one of the only 14" beam blades available for the yaris.
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Wiper Blades futdechenes General Yaris / Vitz Discussion 44 06-27-2010 11:08 AM
What kind of wiper blades? buyah123 DIY / Maintenance / Service 9 11-25-2008 05:25 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
