Old 11-28-2011, 08:05 PM   #19
TURBO YARIS
Drives: Yaris
Originally Posted by djgab101 View Post
Oh but if I don't use it can I leave it open?
Yes you can.....
TURBO YARIS is offline   Reply With Quote
Old 11-28-2011, 11:45 PM   #20
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
don't do that! run coolant through the turbo. it's there for a reason.
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 11-29-2011, 10:19 AM   #21
djgab101
djgab101's Avatar
Drives: toyota yaris
I didn't get any fitting for it that's why I was wondering why it was there I was thinking about it and decided I would add the coolant lines in to cool the turbo just need to find out the fitting size and wat I need to get it to work :)
djgab101 is offline   Reply With Quote
Old 11-29-2011, 07:23 PM   #22
scioncrew
scioncrew's Avatar
Drives: SCION tC
measure the hole with some caliper. more likely going to be a 10mm or 12mm x 1.25 or 1.50 banjo bolt
Old 11-29-2011, 09:38 PM   #23
djgab101
djgab101's Avatar
Yes I shall do that but currently having issues with exhaust bolts not coming loose and those bracket bolts also not moving I applied some wd40 and will give it another go with the extension bar and and a rubber hammer
Old 12-19-2011, 09:43 AM   #24
djgab101
djgab101's Avatar
Started up my car today idle was great no problems !! Only issue was a oil leak from the return hose haven't had a good look but I think the whole return hose is bad joins... Tomorrow going to raise it up and check it out...
My oil gauge was reading at idle 33 psi to driving under 80 psi according to service manual that is within the cars range I thought oil leak would effect that so it must be a small oil leak...
Should have photos coming up soon :)
Old 12-30-2011, 06:35 PM   #25
david_mackk
Drives: Yaris 5dr LB
Any updates? I think you might be the first in aus to turbo a yaris ..... Very jealous :(
david_mackk is offline   Reply With Quote
Old 01-02-2012, 12:37 PM   #26
djgab101
djgab101's Avatar
Hey sorry have been so busy with Christmas car is running so well turbo in hitting boost with no problems!!! Need to get it tuned just trying to make time to get it tuned and have dyno sheets up hopefully before and after! Pictures coming soon :) I think I am the first is aus :)
Old 01-05-2012, 09:46 PM   #27
djgab101
djgab101's Avatar
hey guys finally have some photos up!!
everything is in.. 10 of my friends all put money in and brought me the AEM fic for my bday :D so i am going to get the boomslang from microimage
Old 01-05-2012, 11:52 PM   #28
Love the gauges.
Good job on the install.
Old 01-06-2012, 03:17 AM   #29
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
looks awesome. I am so jealous..
-Derrick-
Old 01-06-2012, 10:45 AM   #30
djgab101
djgab101's Avatar
thanks guys didnt think i was able to do it now i just need to tune it!! since my friends all chipped in and got me the aem fic all i need is the PnP harness from garm :D
Old 01-06-2012, 01:36 PM   #31
I can fix that.
djgab, anytime you're ready, we have at least one in stock.
Old 01-06-2012, 03:25 PM   #32
33OH
Drives: '08 Yaris
Sexiest picture ever.
Old 01-06-2012, 07:39 PM   #33
ilikerice
ilikerice's Avatar
I can fix that.
one day garm.... one day
-Derrick-
Old 01-07-2012, 03:32 AM   #34
djgab101
djgab101's Avatar
I can fix that.
I am ready garm!
PM sent..
Old 01-07-2012, 03:45 AM   #35
djgab101
djgab101's Avatar
Turbo is so worth it .. Huge difference! Makes driving the yaris so much better!!!! I am going to dyno it before I tune it. Hopefully all goes well with the tunning I am going to try do it myself with some help and guidance from forms on yarisworld I should be fine with the tunning I am just going to add more fuel and maybe later on see wat else I can do with the AEM
Old 01-07-2012, 08:41 AM   #36
ilikerice
ilikerice's Avatar
how much boost are you going to go when you tune?
-Derrick-
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Yari Boosted, Enge lite... N3misiS Forced Induction Forum 14 11-20-2009 07:22 AM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
