eBay Projector Headlights...
My stock lights are already clouding up due to the intense sunshine we get here in south-central Texas, and I think the projectors look pretty sweet. Are any of the ones on eBay any good?
I am considering a set, but recall the horror stories of them not being properly sealed or other problems. Is anyone on there selling some that are decent? Is the light output close to the stock units? Firsthand experiences and recommendations would be appreciated! ![]() Cheers! M2
Not quite a noob
Well assuming they're all the same ones you're talking about (the ones that use H1 bulbs), mine haven't leaked yet. The clear finish on them is doing good so far. I've only had them for a few months though.
Also, it rains a LOT where I live. So the fact they haven't yet leaked is a good sign. |
That's the kind of info I'm looking for, thanks!
Cheers! M2
![]() ![]() Drives: 2009 yaris 4dr hb Join Date: May 2010
halo projector angel eyes
Anyone know if the ones on ebay would work on 2009 hb? Ive looked and it tells you that its good for 06-09 but somewhere here in this forums it said that the 09up headlights are different.... Can anyone help me out with this question?
#5 | |
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
I haven't found any 09+ projector headlights like that. |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
Buy morimotos mini h1 projectors! Here are mine!
Cutoff ![]() ![]()
![]() ![]() Last edited by mario98c; 12-01-2011 at 07:55 PM. |
to mario.... would this work for hatch 09? do thy have a wesite I can check?
#8 | |
thanx mario that looks great! wat shroud did you use and bulb?
Not quite a noob
^ cept those are retrofits. They require dremeling and dismantling of your headlight housing
I use the mini gatling shroud with cheap ebay 6,000k bulbs but I want morimotos 5,000k bulbs
In Hb is easy to do... in the sedan is a little more difficult because you need to trim the reflector housing for the projector can fit.
lol. but I think I might have a problem if I have to dismantle my headlight housing... Anyone can show me steps and pics how to do this? I have eyelids from MI and I've already repaired the eyelids twice because it kept cracking and I dont want to affect them... please help lol =)
I saw somewhere in this forum that you have to bake the headlight to dismantle them.. if this is true... my eyelids for sure will get wrecked since I put 3M clear plastic on them also
![]() ![]() ![]() Drives: oliveMist Join Date: Apr 2011
@mario98c
very nice HL @boggydee, we used heatgun and lot of patience in opening our HL. i try to look for pictures on how we did it. see my avatar for the finished product.
- LESS TALK, LESS MISTAKES... - BATO BATO SA LANGIT ANG TAMAAN MAY GALIT |
Not quite a noob
Eyelids are pretty easy to remove. Just get a hair drying and warm up the adhesive and then geta razor blade and very carefully lift the adhesive.
To the OP, you can dehaze your headlights using Plast-X. Then just keep waxing them when ever you wash your car. That should clean it up and prevent it from hazing over.
Or if you get new headlights, just wax them periodically. lol. |
der Zeck
After you clean the haze I would recommend getting them sprayed with an automotive clear that has UV protection. This will prevent them from getting hazed again
| eBay Issue - Your help needed | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 02-04-2011 09:18 PM |
| Cheap eBay LED Strip vs V-LED Strip | Kaotic Lazagna | Cosmetic Modifications (Exterior/Interior) | 1 | 03-18-2010 08:06 PM |
| Pre Hack Revival: Megan Racing Header vs Ebay Header | Sabretooth | Performance Modifications | 15 | 08-19-2009 05:26 PM |
| ebay intake: would you? | thebarber | Performance Modifications | 7 | 12-03-2008 12:44 AM |
