Old 12-01-2011, 03:59 AM   #19
matthewai
matthewai's Avatar
Drives: it is kinda stock
i have stock steelies and just went from a 185/60 to 195/55 i dont think it throws off the speedo and its a subtle difference look wise but you can kinda tell its a little wider obvi. but feel wise it seems alot more stable and better grip when taking turns in my opinion, overall im happy. i also have 19mm rear sway bar and mi springs
Old 12-01-2011, 08:25 AM   #20
A-Dingo-Ate-My-Baby
Drives: yaris
your speedo will read 1.2 percent too fast on 195/55 vs 185/60
actual speed 59.3 speedo reads 60
http://www.tacomaworld.com/forum/tirecalc.php
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-01-2011, 10:41 PM   #21
kimona
kimona's Avatar
Drives: 2014 White VITZ
(QUOTE=A-Dingo-Ate-My-Baby;616875]your speedo will read 1.2 percent too fast on 195/55 vs 185/60
actual speed 59.3 speedo reads 60)
This would be true if the speedo were acurate out of the box with the 185/60/15's... but it isn't.
I went from 185/60/15's to 205/50/16's (1.5% taller) and now my speedo is dead on!
Anyway, if you don't plan to drop the car, I would recommend replacing the 185/60's with 195/60's (2% taller) or 205/55's (0.7% taller). They'll fit the stock steel wheels comfortably and safely.
Old 12-03-2011, 03:00 AM   #22
rufnnek
rufnnek's Avatar
Drives: oliveMist
195 will make your car look normal on the other hand 205 will make it look like it has more muscle.
- LESS TALK, LESS MISTAKES...
- BATO BATO SA LANGIT ANG TAMAAN MAY GALIT
rufnnek is offline   Reply With Quote
Old 12-06-2011, 09:44 AM   #23
Blue Beast
Drives: 2010 Yaris 3 door hatchback
Thanks, I thought my steel wheels were 6.5 but you are absolutely correct. I do then have to agree A-Dingo the 205's might not look right on the stock wheels even though the tire calculator from the link above putting in 205/55 tire size it says it takes a Rim Width Range of: 5.5 - 7.5 in and Rim Width Range of: 5 - 6.5 for 185/60's. I guess my stock rubber when switched to the 6.5 Motegi rims performing so much better was a result of how they were seated on the wider rim, those GY tires were great for a while.
MI Crank Pulley
DC Sports Header
TRD Stainless Sport Exhaust & TRD HP Air Filter
TRD Sport Shocks, TRD Lowering Springs, TRD Rear Sway Bar
MOTEGI RACING MR121 RIMS 15 x 7, Kumho Ecsta RSX 205/55/15
TWM Short Shifter, Base & Cable Bushings, Weighted Hybrid Shift Knob
VG Shark Fin Antenna, De-badge factory emblems, TRD Black Chrome Badge
Blue Beast is offline   Reply With Quote
Question about tire size with TRD drop. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 01-29-2009 05:30 PM
Tire Size Question Yaristwn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 01-29-2009 01:28 PM
Tire Size Question ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 10-30-2008 12:53 AM
noob question about stock tires xCookiE Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 06-19-2007 08:40 AM
