Old 11-29-2011, 08:00 PM   #1657
TOLMACH
Drives: soarer
I am not trying to say these bros can't sound good.. just saying the graph looks kinda cheap .. how much do these speakers retail for?
I stopped dreaming about "the best" speaker couple years ago.. every speaker is a compromise - you get something and loose something else.. there is a bunch of decent midranges nowadays
Old 11-30-2011, 12:06 AM   #1658
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Exclamation
About $540 for a pair of HAT L4SE + shipping.
D.
CLA 250, 4MATIC
Old 11-30-2011, 12:14 AM   #1659
derickveliz2
Exclamation
There are several things to talk about here:
axial response is the predominant topic.
The response is NOT the only thing you must be concerned with when dealing with placement of speakers, especially the vital mid range which is what we hear most predominantly. The axis and height of the physical speaker placement has phasing issues to consider when listening. This is where crossover points, amplitude, and time alignment come into play.
In my listening, I've found that the PLDs, axial positioning, and height have almost everything to do with the performance of the speaker.
What's our reference for great sound?
Lot's more questions to ask.
So what do you think about my theory, have you seen this topic at a pro level?
Our reference for great sound is "LIVE music"
D.
CLA 250, 4MATIC
Old 11-30-2011, 12:23 AM   #1660
derickveliz2
Lightbulb
I wondered about the bottom end of that 6".... I know your dealing with a different class of speaker than me, but my 8" cant reach the bottom end with any authority.
Don't get me wrong, the little I6SW performs really good for SQ (I'm very pleased with the results), but once you get out of the car the magic is gone, in other words from the outside sounds like a guy inside his car playing loud music, "not realizing how good sounds inside", and just for fun some times the kid inside of me want's to sound BOOM BOOM for a couple of minutes jeje.
This is an idea I got at DIYMA website, and I just for fun I would like to try it out, I have an amp and a woofer sitting in the closet.
and I forgot about the:
- SubFloor for the amps, got to finish that as well
D.
CLA 250, 4MATIC
Old 11-30-2011, 12:45 AM   #1661
sqcomp
Roadrunner Jr.
sqcomp's Avatar
That illustration is sort of the same thing I'm doing. You've seen the pics of my kicks. The angle of the passenger's kick is more on axis BUT farther away. The driver's side kick is closer and a little less on axis. The thing is that they're taking a mean point between both axial response and PLDs. So yes, by that mode of thinking this should be successful.
Also, I can reference the pro level...for instance, Bill Pleasant's Altima. His mid range speakers are 90 degrees in the driver's kick and 75 degrees on the passenger's kick. They aren't angled up at all. He's got the tweeters in the pillars at the same angles. World champion vehicle in USACi. Do we theoretically have better setups going? Yes. There are more factors going into the sound (even down to barometric pressure) but we're doing fine where we are heading.
Thoughts?
― Thomas Paine
Old 12-01-2011, 11:57 PM   #1662
derickveliz2
That is so cool, it makes sense.
I always asked my self... "Why would you aim both drivers symmetrically when the listener is not in the center?"
Just for the record, some "so-so" songs sound great now. Even if I don't like them.
I'm adjusting T/A using "pink noise" in different frequencies from 200Hz up to 2kHz, where should I put more attention? 500Hz? or 800Hz? or?...
Works pretty well but some times the center image shifts right or left a little bit depending on what frequency I used last. I wish there was a track like the one in IASCA CD (12 Staging #4 Technical Track Left, Center, Right Narratives) but rather than having all 3 voices going on and off, have a Center that would play continuously all the time, any body? If you don't know what I'm talking about PM me and I'll send you a copy of the track, even if you are just curious about what we are talking.
Now it's harder to work on my car, every day it's colder, but at the same time even everything is sort of temporary install sounds so good that I don't want to work on it and not having the car ready for next day because I don't want to miss a day of music on the road.
Any way... going downstairs to do some carpet/MLV/CCFoam and what ever it takes to finish the right side kick area.
D.
CLA 250, 4MATIC
Old 12-02-2011, 06:08 PM   #1663
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Why not put the phasing narrative on the IASCA disc? Just put your P-99 on track repeat...
Put the speakers symmetrically to the listener. This gets much harder to do with a two seat tune.
― Thomas Paine
Old 12-02-2011, 06:50 PM   #1664
derickveliz2
Good idea, I'll try that tonight!
Why symmetrically?
I don't have my MIDs like that, mine set up it's more a one seat tune.
D.
CLA 250, 4MATIC
Old 12-02-2011, 11:25 PM   #1665
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'm thinking that we have a translation issue. I'm agreeing with you.
Recall your goal of equal PLDs? Symmetry. We're trying to get those speakers as far away at equal distances from us on the same plane.
That's all I was saying.
― Thomas Paine
Old 12-02-2011, 11:34 PM   #1666
derickveliz2
Talking
Jaja! it happens to me all the time!
Yes, PLDs rock for SQ sound, I learn my lesson.
I'm heading downstairs, I would like to finish the kicks tonight, and called "done, for now" and move over to install the HAT L6s, I'll have to do a baffle like you did and get more Mat to for the plastic panels.
D.
CLA 250, 4MATIC
Old 12-03-2011, 03:09 AM   #1667
derickveliz2
OK,
Mids are properly installed in the kick area, at least functionality; aesthetically mmm not quiet like when I had them in the a-pillars.
Next step: HAT L6s in the doors.
D.
CLA 250, 4MATIC
Old 12-03-2011, 04:18 PM   #1668
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Pics or it didn't happen! :P
Let's trade notes on the doors. I've my SEs in the doors. I'm in a holding pattern to make the panels more aesthetically pleasing with some trim work and grills...that will come...after the trunk and tweeters. I can plug power in and get good, beefy (unequalized) sound out of the SEs now.
^There's an edge on that kick that I can see...I want to smooth that down before the glaze goat.
― Thomas Paine
Old 12-03-2011, 07:55 PM   #1669
sickpuppy1
Drives: 2010 Yaris Sedan
Yeah and the carpets dirty too,lol
Old 12-03-2011, 09:10 PM   #1670
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Oh man...this car isn't going to be vacuumed until I'm done. You should see the interior. Lots of fiberglass dust.
I'm going to be forced to clumk down 5 C's for a new floor carpet when I'm done. I was stoooooopid and said F it, then cut into the carpet about 6 months ago. Dumb move. Oh well, I'm lucky to have that change to spare.
― Thomas Paine
Old 12-09-2011, 01:42 AM   #1671
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Okay Derick...what are you up to? I'm into my pillars now. I'll be glassing soon. I'd expect to have both pillars roughed in by Christmas.
― Thomas Paine
Old 12-10-2011, 09:12 AM   #1672
derickveliz2
I've been trying to work on the L6s in the doors, so far I made a baffle for the pilot's side (see photos below) ugly and painful, I'm going to make a plan (drawings) and ask a local friend to cut the other side for me. The good thing is that you don't see this, any way shame on me, but it works and that is what counts.
On the other side, we (as family) have been sick and barely had time to work, I did take some pics of the kick's with the MIDs but still in my camera, will upload later on.
D.
CLA 250, 4MATIC
Old 12-10-2011, 02:07 PM   #1673
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The important thing is that we're all still moving forward. I've got my driver's side a pillar out with the tweeter baffle all glued into place. I'm looking at carving out some more of the OEM plastic so I can make the angles more agreeable aesthetically and output-wise. I may just paint the a pillars the OEM color as well to match the entire front of the car up.
― Thomas Paine
Old 12-10-2011, 02:34 PM   #1674
TOLMACH
Drives: soarer
Derick,
Your rings looking good.. you plan installing the speakers under the door panels, right?
Asking - just make sure your speaker is not playing under the panel.. use some foamy material around the speaker to prevent sound going around under the panel rathen than through the panel grille outside (sorry, English is not my mother tongue)
