Somebody steal the motor....
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
You know that is just a slightly modified version of the 1.8L they are putting in the Yaris TS. It is already in the Vibe GT/ Matrix
#3 | |
![]() ![]() Drives: 07 Yaris LB, 70 Mach 1, 84 5.0 Join Date: Feb 2007
EDIT: I actually think the new 1.8 will be a modified 1nz, but who knows. Last edited by Dragonacc; 03-12-2007 at 08:35 PM. |
#4 | |
![]() ![]() ![]() Drives: 03 Toyota Corolla S modded, Join Date: Jan 2007
The engine they used for the Scion xD and Yaris TS is the 2ZR-FE "ported/modified 1NZ block" dual VVT-i, its more high-tech than than the 2ZZ-GE with VVTL-i but with less power because it doesn't provide intake valve lift but, it does also control the exhaust valve timing... just like the IS-350 with a smaller displacement. I hope this enlightens you... They have plans on making a Dual VVTL-i for the upcoming 2010 "KING" Supra!
#5 | |
As far as a new Supra is concerned... I believe it when I see one sitting in a Toyota dealership. EDIT: Also note the engine name, uses FE at the end designating an economy engine rather than a performance engine. |
I think I'd rather just have the Exige. It would be a nasty swap though.
The 1.8 of the Yaris TS is a new block, the 2ZR-FE, successor to the 1ZZ
toyota
the yaris got the matrix base engine...vvt-1 140 hp.. not the vvtl-i from xrs...by the way this wll be reuse for the new toyota blade!!
der Zeck
still doesnt even break 140hp
| A/c blower motor noise!!!! | LBdriver | General Yaris / Vitz Discussion | 28 | 09-12-2007 07:46 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
| Yaris T-Sport showing at British Int'l Motor Show | VitzBoy | General Yaris / Vitz Discussion | 3 | 07-22-2006 12:01 AM |
| Motor Silk | jcove | DIY / Maintenance / Service | 3 | 04-09-2006 07:54 AM |
