Old 12-16-2011, 02:59 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Light Weight Wheels
I am planning to replace all 4 rims to some light weight ones.
Presently I am running 15 inch alloy wheels (don't know offset) with 195/50 tires. I would like that the new wheels would be 45 or near offset and 8 inch wide.
I don't need a brand in particular although these are the requirements:
- Similar to picture below. Black with outer red. Different design is accepted
- Light weight
- Price must not be overhelming
- 15 inch size and 8 inch wide with 45 offset
- Preferably from UK stores
Parmas is offline   Reply With Quote
Old 12-16-2011, 04:02 AM   #2
look into Wolfrace or Team Dynamics, always see ads for them in UK Magazines, seems like good bang for the buck...
Old 12-16-2011, 10:04 AM   #3
Motegi mr125....almost as light as enkei rpf1's, but half the price...
Only as small as 16" though
Old 12-16-2011, 11:20 AM   #4
Parmas
Parmas's Avatar
During some research I found some good info on this article.
Surely needs to be checked out
http://www.tirerack.com/wheels/tech/...jsp?techid=108
Old 12-16-2011, 03:00 PM   #5
you can get RPF1's and add a red stripe.
Old 12-16-2011, 10:05 PM   #6
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
949 racing 6ul wheels.... I recommend those. You can get 15 x 7-10. 15 x 8 are 12.3 lbs each. I would think 45 offset would be too sunk in? I run 36 along with a 20mm spacer, so essentially I'm running a 16 offset. It sits just inside being flush when I run -2.7 degrees of negative camber.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 01-05-2012, 11:41 PM   #7
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
the answer would be rpf1s
Old 01-06-2012, 07:02 AM   #8
Kosei k1 ts
OZ superleggera or ultraleggera
Old 01-06-2012, 10:16 AM   #9
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
performanceplustire.com
cheapest place I've found, got a set of Konig Heliums shipped to my door for $385
Heliums weigh something like 10.8lbs each
Captain Slow is offline   Reply With Quote
Old 01-06-2012, 12:01 PM   #10
EPyarisdriver
...or Vegas for short
EPyarisdriver's Avatar
Drives: 2010 Toyota Yaris 3door LB
Either the Enkei RPF1s or the Konig Heliums. Both are awersome!
EPyarisdriver is offline   Reply With Quote
Old 01-07-2012, 01:28 AM   #11
Parmas
Parmas's Avatar
Thanks all for your feedback I would keep this thread in mind for the next upgrade
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
6lb 6oz ultra light weight battery heavystarch Performance Modifications 28 11-19-2008 07:02 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
