![]() Drives: ewdew Join Date: Mar 2007
i happen to have a 1.8 fuel injector
hi, i happen to have a 1.8 fuel injector 2nd hand imported from japan for use on 1.5 1nz-fe engine, its greenish in color, so far the guys over her in singapore used it on 1nz-fe engine and got quite a hugh gain, i wonder if you guys have tried that before?
der Zeck
what is the injector out of, I bet I could pull a set out of a Matrix/Vibe for free
most likely the 1.8 corolla or celica
Break'em off some.
A bigger injector is not going to do anything. Adding the injectors by themselves will make the car slower. If you tune for them, it is the same as tuning with the stock injectors. The stock injectors are fine with no power adders.
| Fuel Capacity ? | ttufrosty | DIY / Maintenance / Service | 19 | 08-27-2013 12:14 PM |
| Increased MPG or HP anyone???? | slvryaris | Performance Modifications | 55 | 05-27-2007 10:49 AM |
| higher octane fuel | KSIbucky | DIY / Maintenance / Service | 37 | 01-14-2007 07:17 PM |
| My problem with my car; help(gas econ) | Lafiro | General Yaris / Vitz Discussion | 42 | 11-14-2006 08:32 AM |
| Consumer Reports on Ethanol | Driver | General Yaris / Vitz Discussion | 6 | 09-01-2006 11:21 AM |
