Old 01-09-2012, 09:08 PM   #1
Crackerballer
Drives: 08 BMW 135i
Same size wheel, different offset.
Guys, thinking of ordering these for the Yaris:
http://www.tirerack.com/wheels/Wheel...7&autoModClar=
Problem is, Tire Rack says two offsets fit, both +42 and +38. Which ones should I order? I plan on getting 215s put on them and the car will be lowered slightly. Thanks.
Crackerballer is offline   Reply With Quote
Old 01-09-2012, 10:10 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
The difference is a few millimeters. The +42 wheel will sit slightly farther inside the wheel well compared to the +38 wheel. I would go with +42 to be safe.
20lbs. is heavy wheel, but seems to be the going weight for cast 17" wheels.
Old 01-09-2012, 10:23 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
I had a set of 16" ASA AR1's on my car with 45's up front and 38's in the rear.
If you don't want to stagger offsets, I would definitely go with 42's.
Old 01-09-2012, 10:38 PM   #4
Crackerballer
Drives: 08 BMW 135i
These are my first option, not sure I want to spend this much though:
Bolt Pattern Size and Offset for the Stock Wheels fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-12-2009 03:35 PM
Which wheel size with DF210īs? Danish Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 02-03-2009 01:28 PM
Whats the highest offset and tire size for 17s you could go... YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 12-15-2008 09:40 AM
Wheel offset questions.. Jerkratt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 11-04-2008 01:32 AM
