![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
Turbo Timer!!!
Guys recently installed my turbo and have tired to install my very basic turbo timer but have been having a few issues!! My timer has only 4 wires
Red - constant power Black - negative battery Yellow - ignition Blue - This wire must be connected to acc or won't work My issue timer is on .. I turn off car timer counts down and car has stopped running :( I was thinking that I have yellow wire connected to wrong ignition wire to the car does anyone know wat colour the ignition wire is? http://www.piranhaoffroad.com.au/med...204%20wire.pdf
Mr. 155 and climbing
PM CTScott and see if he can provide you any info. On a side note I would suggest you eventually move over to liquid cooling for your turbo rather than doing the turbo timer IMHO.
Thanks i will :) when u say liquid cooling do u mean oil or coolant or both?
There are two ignition wires on the Yaris - The Pink wire and the Green Wire on the ignition switch connector. The pink is the primary, so try that first, but the green may also be necessary to keep it running. If that turns out to be the case, you will need to have the turbo timer switch a dual pole relay and then connect the relay to the two circuits.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| turbo timer | Scubaru Steve | Forced Induction Forum | 5 | 07-04-2011 07:19 AM |
| HKS Turbo Timer | Nas_RS | Cosmetic Modifications (Exterior/Interior) | 8 | 10-23-2009 07:39 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
