Old 01-30-2012, 09:29 PM   #1
badmofo
Drives: '07 Yaris Liftback, Basic
Yaris engine noise (Video)
I had trouble starting the Yaris this morning, 2 times it ran rough for a few seconds then died. Now it has this growl/whine that is tied to engine speed. I loosened the belt checked the ALT, AC, Water Pump - they seem ok. What else could this be?
http://youtu.be/od1V63stgEQ
badmofo is offline   Reply With Quote
Old 01-31-2012, 08:06 AM   #2
CB900F2
Drives: 08 Sedan
Sure sounds like a bad bearing
CB900F2 is offline   Reply With Quote
Old 01-31-2012, 09:27 AM   #3
It sounds like the alternator has a bad bearing. You could take the belt off and run it for a few seconds (not too long since the water pump won't be running) to verify that it is one of the things driven by the belt as opposed to the engine itself.
Old 01-31-2012, 09:43 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I have a similar noise.. i was hoping it was the water pump personally.. I did install NST pulleys on alt and water pump.. When I took the belt off, The noise went away.. let us know what you find
-Derrick-
Old 01-31-2012, 12:14 PM   #5
badmofo
I removed the belt and started the engine for a few seconds, the noise is definitely something driven by the belt. I cant tell which one by spinning them with my hand, but the alternator has a little more resistance when turning. Any way to tell for sure? Thanks for the help guys, I appreciate it!
Old 01-31-2012, 12:36 PM   #6
ilikerice
ilikerice's Avatar
I was just thinking.. If you had a battery powered drill at your disposal, you could take the alternator off and put the correct socket on it, and pull the trigger, see if it makes that bearing noise a little bit.. Id try this now but im at work.
I will prob try this this weekend
-Derrick-
Old 01-31-2012, 03:05 PM   #7
badmofo
Derrick, good idea. I'm going to try that right now, errr after a cup of coffee.
Old 01-31-2012, 03:33 PM   #8
badmofo
Well the coffee gave me another idea that actually worked. I wrapped about 5 feet of paracord around the alt pulley and gave it a hard pull. It did not sound good, so the official diagnosis is the alt bearing. Is the bearing replaceable or am I looking at a new alt?
Old 01-31-2012, 03:43 PM   #9
Toyota only breaks the alternator down as far as replacing the entire rotor assembly (with the bearings already pressed on) for about $200, so it would be a case of having to find the correct sized bearings or simply buy a low mileage junkyard alternator.
Old 01-31-2012, 03:52 PM   #10
badmofo
Would you recommend an aftermarket part? CTScott and Derrick, you have my respect and admiration.
I have just enough knowledge to be dangerous.
Old 01-31-2012, 04:06 PM   #11
I wouldn't recommend an aftermarket alternator, as others who have use them have had issues with the charging warning light flickering. I would stick with an OEM one and try to find an 08 or newer one to avoid a potential issue with the voltage regulator corroding (of which there was a TSB on for 07).
Old 01-31-2012, 07:14 PM   #12
ilikerice
ilikerice's Avatar
Better idea than I had.. Coffee always makes you think smarter and faster. 1 cup a day for me every morning. I think I just drink it for the taste now, I can literally drink coffee to fall asleep.
I will try your idea this weekend also..
-Derrick-
Old 01-31-2012, 09:40 PM   #13
badmofo
I have to give you some credit for the idea, you got the ball rolling. Well the stealership is $635 richer and Im broke, but at least the Yaris rus perfect now and I am the owner of free camo Toyota hat. I didn't even complain about the price! Thanks again guys!
Old 02-01-2012, 04:38 AM   #14
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
$635.00 for the alternater or that includes installation.
yaris4062007 is offline   Reply With Quote
Old 02-01-2012, 09:33 AM   #15
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Wow that is obscene for just an alt..
Noise from rear of Yaris APS67 DIY / Maintenance / Service 5 09-25-2011 07:51 AM
