Old 02-11-2012, 12:58 AM   #19
Hershey
Eco-Meter . $65 .
Old 02-11-2012, 03:46 AM   #20
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
^That's two for the Eco-meter.
I'ma put it and oil in the lead.
-Will-
Spidermandud is offline   Reply With Quote
Old 02-11-2012, 09:47 PM   #21
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
for the price difference, you get more with the ultragauge. ecometer displays like two different things where as the ultragauge displays 6 and will reset trouble codes and CEL codes. (not sure if the ecometer does this).
I'm still a big fan of the scangauge 2 though the price difference is huge at roughly twice the cost.
Old 02-12-2012, 10:40 AM   #22
2005rs
Drives: 2005 Echo Rs
I really like android torque. I can choose what I want to display and how to display it.
2005rs is offline   Reply With Quote
Old 02-13-2012, 02:05 AM   #23
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Best investment for MPG? At the endo of it, the best bang for the buck is still air pressure! For the most part it is free...
Old 02-14-2012, 10:04 AM   #24
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
I agree with air pressure. On a car as light as the Yaris the extra air doesn't cause that much early tire wear. If you are diligent about tire rotation and constantly check the tires for pressure, you can get about 2-4 extra mpg by over inflating the tires.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 02-16-2012, 03:58 PM   #25
Spidermandud
So anyone else got any run downs? Anyone ever put absolutely everything on their car to improve gas mileage, save maybe forced induction?
-Will-
Old 02-16-2012, 06:03 PM   #26
BEEF
BEEF's Avatar
not a yaris but....
http://www.aerocivic.com/
used to be a member at gassavers
http://www.gassavers.org/garage/viewgaslog/2694?
http://www.gassavers.org/garage/view/2694
there are several forums dedicated to just fuel savings and fuel economy.
Old 02-20-2012, 04:50 AM   #27
Spidermandud
Not quite what I'm looking for; but that's definitely neat enough haha. I was looking more along the lines of simple mechanical things you could do; and what their benefits are. ... Just 3 more months til I move. . . then i'm gonna say a few weeks to get a job. . . then I'll have two months before school starts again. . . Hopefully at some point during all that I'll be able to throw some $$ into some gas-mods. :D
-Will-
Old 03-14-2012, 12:28 AM   #28
dtbrown
Drives: Yaris
Only investment that gained me MPG was my Injen CAI. I tested before and after and I gained almost 2mpg. The down side is torque is fairly noticeable and sound is great so you get on it a little more and then I'm right back to where I started mpg wise. :)
dtbrown is offline   Reply With Quote
Old 03-14-2012, 12:41 AM   #29
TLyttle
TLyttle's Avatar
For the Canadians on here, I recommend MolySlip; maybe there is a US equivalent, the description is "molybdenum disulfide in suspension". I am sure I am getting 5-10% better mileage by using it in every second oil change...
Old 03-14-2012, 11:23 AM   #30
samuraivince
samuraivince's Avatar
Drives: 08 Yaris hatchback
what tire pressure would you guys recommend is best? we have a lot of pot holes in MI so i couldnt over inflate them.
samuraivince is offline   Reply With Quote
Old 03-14-2012, 01:11 PM   #31
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
For the tire pressure question: I am using the max sidewall which is 44psi on both sets of tires that I have had. (101K miles)
If you are not comfortable with that, start at 40psi and try it for a month.
There are a number heated discussions in the threads about raising tire pressure over the number on the door placard. But 40 to 44 seems to be good range for those that want to raise it.
For me increasing from the dealer set pressure of 28psi got me from 36 to 40Mpg. Practicing my commute with a ScanGaugeII for 6 months got me from 40 to 45Mpg.
SpaceShot is offline   Reply With Quote
Old 03-14-2012, 09:42 PM   #32
Hershey
We use 35 > 36 p.s.i. and get 38+ m.p.g.. Easier on the tires and suspension when hitting that unsuspected pothole . Getting little over 41 m.p.g. at this time with 4 Blizzak WS70s set at 35 .
Old 03-14-2012, 10:16 PM   #33
samuraivince
thanks! so i take it anything close to 45psi is too much?
Old 03-15-2012, 12:37 AM   #34
TLyttle
TLyttle's Avatar
I heard somewhere that the sidewall max pressure has to do with mounting the tire, then it is pulled down to doorpost recommendations. Personally, I run about 4lbs below mounting pressure, big increase in mileage, and somehow the car feels more "alive"...
Old 03-15-2012, 03:10 AM   #35
Spidermandud
http://www.walmart.com/ip/Gas-Saver-...36psi/16776208
^Random thought; haven't seen anyone mention these on here.
I try to stick right around 40 myself. The ride seems lighter; less rigid.
I wouldnt think 45 psi would be too much pending what you're tire's rated. . someone on here I remember mentioning they run theirs at like 60 psi haha.
-Will-
Old 03-15-2012, 04:07 PM   #36
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
so you installed the cai and you gained low end torque and gas mileage? Wow that is pretty sweet.
Colin Chapman disciple
Why sub-compacts and compacts get almost the same MPG Kal-El Off-topic / Other Cars / Everything else Discussions 0 08-11-2011 12:51 AM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 01:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 12:49 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 06:48 PM
