![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
Fuel pump
hey
has anyone installed the walbro fuel pump 255lph into there yaris? i was going to order it and install it myself just wondering how difficult it is? does the walbro fit straight in and replace or does it require some modifications?
Requires some small mods. Your stock pump is the size of a "D" cell battery, lol.
I'll try to find my pictures, I'm using the same one.
all I can find so far:
Here are a coupe more:
Fuel sender assembly with pump inside: Sender - Gauge.jpg Pump assembly removed from the sender (filter end view): Fuel Filter.jpg Pump removed: Fuel Pump.jpg
Just got my walbro fuel pump in good time car barely runs down the road not enough fuel pressure! I took apart my fuel assembly to find that the walbro does not fit into the pump assembly the walbro is a bit to big .... Any possibility I can run the pump outside the assembly ? Or maybe configure a new bracket inside the fuel pump any ideas or feedback?
Return it and get the 190lph for the MR2 or corolla 255lph they should fit.
| Fuel Pump Failure | eaglerox | DIY / Maintenance / Service | 14 | 03-02-2013 10:27 AM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Noisy fuel pump or not | johnlui | Australia | 0 | 06-16-2011 08:26 PM |
| i snooped around a lil but couldnt find. does fuel pump come on? | severous01 | DIY / Maintenance / Service | 4 | 01-31-2010 09:25 PM |
