Spring rates
Anybody know the spring rates for the OEM springs? trying to look for something that will actually improve my handling, and not just make my ride harsher like my echo...
![]() ![]() ![]() Drives: 03 Toyota Corolla S modded, Join Date: Jan 2007
if you cut your stock springs you will have the same spring rate...
but, with lowering spring there should be about a 30% spring rate increase some are 15% for comfort... try Tanabe, they should have something called an NF210 and DF210... add upper front strut bars and upper rear bracing, it should cost you $160 for front and rear... change the shock and struts too with harder ones, and your ready for Auto-X buddy you might want to custom make some under-bracing with your welder buddies because they cost a leg ...
hey, i'm asking for the oem spring rates... i'm not asking about what increase... :sigh:
as for my echo, i had the eibach pro kit's... and that did nothing to help handling. |
#4 | |
ask Etimago about that... BTW, Eibach suck when its cheap! |
trd is eibach?
(god this girl on my phne talks so much, i never tho gurls could but this annoying...I can think of several things to shut her up if she was here) sht wont shut up!!! -- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
from what i hear, TRD are rebadged Eibach's.
TRD sportivo's aren't as stiff as the eibach pro kit's i had. possibly still eibach but not the pro kit.
and no, i'm not going to choose a suspension setup without knowing what i already have. say the oem spring rates are 300/150, and you get new ones that are 600/300, then it's going to be totally useless except making the ride harsher. you see what i mean? |
i can't belive nobody has any info about this :(
Have you tried to contact Toyota? or an aftermarket spring company like Tein or Tanabe. I bet they could tell you in 5 minutes.
i have hard time figuring out how to call "spring rates" in french lol. There's the problem :P
track or die
Drives: Yaris LB CE CDM Join Date: Jun 2007
ttt
| Toyotaland Spring Meet April 21, 2007 | MtyMseHArmer | Rocky Mountains / Great Plains | 13 | 03-31-2018 02:31 AM |
| TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 09:26 PM |
| FS: CUSCO Compact S Coilovers (SoCal) | 03Z33 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 02-14-2007 12:21 AM |
| 17" Kobe, Spring Tech, TRD | FlintS | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 09-24-2006 10:39 PM |
| Spring Install Price | redglare45 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-30-2006 08:32 PM |
