![]() Drives: yaris 07 Join Date: Feb 2012
what suspension kit should i use for yaris 07
thanks for the people that are willing to give an advice :)
also if u install lowering springs. does it mean you should buy a new shocks or struts ? just thinking :) also what is the differences of coilover to damper kit ? Last edited by yell; 02-28-2012 at 11:42 AM. |
Read thru this first:
http://www.yarisworld.com/forums//showthread.php?t=8342 Determine your budget and your goals. Check out microimageonline.com and/or talk to "Cali yaris" aka Garm. He can get you what you want at the lowest price available, will even price match if you find it somewhere else cheaper. Get back with us on your choices and we can help you further
What are you personally looking to achieve?
Drop: mild, moderate, or slammed Ride: OEM comfort, bone jarring stiffness, or somewhere in between
You could install new struts if you want, a lot of people left the shock and strut stock. Generally, stock strut/shocks may wear out a little quicker, so keep that in mind. Aftermarket (performance) struts and shocks often add a degree of stiffness.
tnx for the answer :) anyway what is the difference of damper kit and coilover ? thanks :)
damper is usually the adjustment of the shock's Hard and Soft settings. Some coilover kits have dampening adjustments.
Just regular coil overs are just a spring that has adjustable hieght by using keys. You are just moving the spring Higher or Lower from the shock housing itself
#8 | |
you mention height so does it means coil overs are just like lowering springs or if i buy lowering springs then i should buy coil overs too ? sorry for the stupid questions lol! but everyone is new at one point :) |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I run Tanabe NF210 and stock struts on mine. Going to have to replace the struts though, one of the rear ones has given out on me. Ride is comfortable and handling was improved a LOT. It is a bit bumpy on poorly paved roads but I prefer that over a "squishy" feeling car. On the occasion that I drive my mom's Accord I feel like I'm on a boat.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
Form>Function
I have springs right now on an 07 sedan and the drop is pretty low for springs (~1.9in).
It is advisable to replace struts only because the new lower stiffer springs may wear out the factory spec struts more quickly. If you replace the stuts and springs together you wont have to go back under the car. But replacing the struts is not required. Lots of us are on springs with stock shocks. If you can afford coilovers and are trying to go pretty low then I would recommend getting them. They should all be ride height and damper adjustable and they will give the most extreme handling and lowering you can get on any ride. Or you can do what I did, buy some springs, get used to the feel and the drop and then save your money til you can get some coilovers. GL and you may want to search. You will find a lot of great info. |
#11 | |
2nd pic is just a lowering spring.. nothing to adjust, so height is really determined by what the manufacture says and how much weight is in the car. ex, sound sytems... also they do not come with shocks, will have to buy separately as other here are suggesting 3rd pic is basicly what a yaris coilover is. Its usually a kit with adjustable springs and comes with shocks. these are usually more aggressive and stiffer ride, but completely adjustable for that mild look or slammed look
tnx for the friendly advices thanks so much :) especially derrick :)
| FS: OEM Toyota Vios Turbo Kit | CTScott | Items for Sale by private party | 24 | 07-31-2011 10:12 AM |
| Blending a Kit With a Factory Bezel | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-03-2010 12:54 AM |
| ANCLA turbo kit warning! | 1.5 | Forced Induction Forum | 11 | 02-26-2010 09:04 PM |
| Suspension Kit: Fully Adjustable or Lower Spring? | JeremyG | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 04-23-2009 09:23 PM |
| Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? | ceboyd | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-08-2006 03:13 PM |
