Old 04-28-2011, 11:17 AM   #1
Split
Drives: 2008 Yaris Sedan
Question horrible idle / engine shake after car audio install
So last night I was looking for something to do and i found some old audio equipment, which I decided to install in my wife's yaris.
1) 4channel ampline amp mrv-something -- powering the factory speakers (extremely low gain)
1) 2channel low-end rock fosgate amp bridged powering 1 10" rockford fosgate subwoofer
When I hooked this all up, the car starts to shake terribly when in drive and holding the brake. if i open the hood, the engine is violently shaking back and forth. It doesnt seem to happen in park or neutral, only in Drive when the brakes or ebrake are engaged.
Any suggestions?
Split is offline   Reply With Quote
Old 04-29-2011, 07:39 AM   #2
Lil Abner
Drives: 2009 3dr LB Manual
Did you take anything apart? Did you remember to tighten the battery bolts down? Did you knock any sensors loose? Unplug any engine sensors? Knock any hoses loose? Does it do it when the stereo is off? Trying first to see if it has anything to do with stereo, and not some other problem that just so happen to come up. :-)
Old 04-29-2011, 08:48 AM   #3
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
i think you should check the electricity system,especially the spark plugs coil. CMIIW
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA
highwaypass is offline   Reply With Quote
Old 04-29-2011, 10:42 AM   #4
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
After you inspect everything for mistakes, try a ground kit, DIY or Ebay for about 20.00...it can't hurt.
-Type 07 FFL-
My odometer 03/11
Old 04-30-2011, 01:01 PM   #5
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Do you still have the stock battery ?
Old 09-11-2011, 01:50 AM   #6
defecta
Drives: 2005 'Silver lining' Yaris YRS
I am having the same problem after disconnecting the battery before inspecting the factory speaker setup. I have absolutely no mods or changes to the stereo or electricals.
Would I be right in thinking it's just the engine management software having forgotten it's settings? Is it just a matter of time before it corrects itself?
Cheers.
defecta is offline   Reply With Quote
Old 09-11-2011, 08:39 AM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Bet it's the air fuel mixture that the ecu have to get use to.. 20 minutes drive fixes it
Old 09-11-2011, 12:42 PM   #8
BLH
Drives: 2007 Yaris Sedan
After they disconnected my battery during a repair.
My 2007 had to relearn the characteristics of the car and did run poorly at first.
Though I never got any violent engine shakes.
BLH is offline   Reply With Quote
Old 03-02-2012, 11:03 AM   #9
Split
^ i took apart the intake and thoroughly cleaned it and the MAF. once i put it back together and reset the ECU everything seems to be fine. I guess it was just a coincidence that it happened right when we installed the stereo.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
