#19 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
#20 |
#21 | |
Idle (650 RPM): 10A 1000 RPM: 35A 1500 RPM: 55A 2000 RPM: 60A 2500 RPM: 65A 3000 RPM: 68A 3500 RPM: 70A
#22 |
CTScott,
Awesome, thank you! |
#23 |
My testing is on hold. I sold my Brutus on Friday and ordered a diff 1500 watt amp should be here sometime this week.
I also need to do a voltage reading on the output of the amp. I remember touching the leads to my Brutus when playing music and it reading less than 10 VAC playing music. While playing test tones I was a constant 34.6 VAC. After seeing the numbers on our alternators I'd feel safe running 600 WRMS. As long as you're not cruising around playing test tones everywhere you go. Would recommend Big 3 and upgraded battery
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#24 | |
#25 |
Alot of people don't like AudioPipe but the clamp and oscope test on this amp have been pretty damn good for the price ! So I'm gonna give one a lil test run.
User manual - http://audiopipe.com/support/manuals...M-1500_eng.pdf
