![]() ![]() Drives: 07 BB yaris / 06 Mustang Gt Join Date: Apr 2007
How to Remove cv axle from passangerside
I am having wheel bearing replaced, i got the tie bar and control arm ball joint removed. Do i tap on the axle with nut to remove it. I hit it with plastic hammer, it doesnt move at all. ;(
Are you having trouble getting it out of the tranny or having trouble getting the hub off of it?
Hub :)
Hmmm - When I changed the passenger axle on Crashy the hub slipping of the splines was the easy part. The service manual shows using the SST 09628-10011, which is basically a puller to remove it. With mine, I just tapped around the backside of the hub with a deadblow hammer until it slid loose.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| DIY : How to remove door panels | FEINT | DIY / Maintenance / Service | 13 | 11-18-2021 02:16 AM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| [DIY] To remove logotipos of the mark | Sérgio Barros | DIY / Maintenance / Service | 6 | 02-23-2007 07:32 PM |
