Old 04-03-2012, 01:46 PM   #145
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Thats a shop here in Tampa. Are you sure that is for the 1nz?
Old 04-14-2012, 10:12 PM   #146
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
this stuff is more exciting that porn! i want 400hp yaris! power to weight would leave mustangs and camaros in the dust.
Old 05-12-2012, 10:53 AM   #147
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
After running in the engine, I had the car sent back for a tune today and things got interesting.
Blue curve - 404 whp, previous base tuning for engine run in, pump gas, 1.6 bar boost, no water/meth.
Red curve - 454 whp, pump gas, 1.7 bar boost, water/meth turned on.
Green curve - 501 whp, pump gas + avgas 50/50 mixture, 2.2 bar, no water/meth.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 05-12-2012, 11:04 AM   #148
That's crazy - CONGRATS on pushing the 1NZ to the new record power levels. 2.2 bar is about 30 psi, right?
Any idea why the power is so much higher than the torque? The gap between the two seems to grow the higher you go with boost and power.
Any videos of a pull? I bet it sounds great at 8000 rpm.
Old 05-12-2012, 12:34 PM   #149
changchewsoon
Drives: Vios Turbo
Hi Garm, I am currently uploading the video to YouTube at the moment.
Not sure why the torque curve is like this, maybe the 1NZ engine is not meant to produce a lot of torque?
But we do know that the power is still climbing at 8000 RPM. Not sure how it'll go if we give it another 1000 RPM.
Old 05-12-2012, 01:45 PM   #150
wowowowowowowow crazy good stuff!
Old 05-12-2012, 02:18 PM   #151
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
holy shit balls batman!
and the winner goes tooo
-Derrick-
Old 05-12-2012, 02:24 PM   #152
vten
Holy batman robin n iron man ...
500 plus on a Yaris ... Even on my AMG with double the Yaris weight I get scared sometimes with the traction control off ....
Old 05-12-2012, 05:20 PM   #153
Golddeenoh
Golddeenoh's Avatar
holy sheeeet 32psi. big boost there big pimpin.
Old 05-12-2012, 05:20 PM   #154
holy Avengers...
what's "avgas"? some kind of race gas, I'm guessing?
Old 05-12-2012, 10:12 PM   #155
changchewsoon
Drives: Vios Turbo
We call them avgas on our part of the world, perhaps it's better known as aviation fuel on your side?
Old 05-12-2012, 10:32 PM   #156
Golddeenoh
Golddeenoh's Avatar
ahh we tend to call it "Jet Fuel" and depending on the grade maybe even "Race Fuel" or "Race Gas".
Old 05-13-2012, 10:59 AM   #157
I'm guessing turbo choice...
And HP = (tq x rpm) / 5252....so at high rpm you need less tq for big hp
Old 05-13-2012, 11:33 AM   #158
I don't see how he could have much more than a GT30 back there.
Old 05-13-2012, 12:49 PM   #159
455whp at 8300rpm = 288wtq at 8300rpm
501whp at 8300rpm = 317wtq at 8300rpm
When peak HP is at such high rpm, you don't need to make a ton of tq up high (relative to HP, that is)
My vibe's 2zzge is 180hp at like 7600rpm and 130tq at 6800rpm...
Old 06-27-2012, 09:16 AM   #160
Hussain-Vtec
Hussain-Vtec's Avatar
Drives: ECHO NCP-12/2NZ-FE
That Nice Curves in Both Congrats.
Time to
***High-Performance Cooling System***http://honda-tech.com/showthread.php?t=3062009
***The Basics of Reading a Spark Plug***
http://honda-tech.com/showthread.php?t=3063102
ALL-TECHwire
Hussain-Vtec is offline   Reply With Quote
Old 07-05-2012, 05:51 PM   #161
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That's a tough act to follow!
Here's the results of my baseline dyno runs.
The engine is bone stock except for:
Weapon R Short Ram Intake with BLOX Velocity Stack Air Filter
Weapon R 4-2-1 Exhaust Header
Mirco Image MagnaFlow Center Exit Exhaust
100 horsepower and 100 foot pounds is not too bad considering just those few mods.
The torque curve is pretty flat overall and peaks at 4,000 rpm.
Old 07-07-2012, 12:01 PM   #162
Hussain-Vtec
That is Nice.
Question what Do you use for tuning your ECU?
Do you have any idea About the Camcon VVT-I Controller
I hear its a nice tuning device.
WR Yaris Intake Picture & Dyno. WRLEO Performance Modifications 37 04-05-2007 07:02 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
