Old 05-17-2012, 09:27 PM   #1
patm
Drives: 2007 yaris sedan
Roof drip molding
Has anyone replaced the Roof drip molding on a 2007 Yaris along with the clips.
My left is gone ???? The right one looked like a mcdonalds arch - U upside down. I flatenned the right one.
It's only a piece of rubber
PatM
patm is offline   Reply With Quote
Old 05-17-2012, 10:39 PM   #2
I haven't replaced one, but have pulled a set off.
For the sedan you can probably reuse the clips, but just in case, the part number for them is 75561-52040. The garnish itself is 75552-52140 (Left side) and 75551-52160 (right side). The clips are about $3 each and the molding is about $30 per side.
Old 05-18-2012, 11:08 AM   #3
Klink10
Klink10's Avatar
Thank you for that info CT.
Old 05-19-2012, 05:21 PM   #4
patm
thanks, will order from trd as i found dealership is expensive they wanted around $50 for rubber and 2 clips. ordering is still cheaper with s/h.
Old 01-11-2017, 03:11 PM   #5
andreas14
Drives: Toyota yaris
HELLO ...I LOST MINE FROM BOTH SIDES..IS IT SO NECESSARY TO INSTALL THEM?AFTER A BIT A HAVE LICK FROM BOTH FROND UPPER ROOF CORNER...IS THAT THE REASON OR HAPPEN BECAUSE OF SOMETHING ELSE
andreas14 is offline   Reply With Quote
Old 01-11-2017, 09:17 PM   #6
SirDigby
Drives: 2007 yaris 3 door
why are you yelling?
Old 01-11-2017, 09:55 PM   #7
dogsridewith
Drives: 2007 2-door hatchback
Yaris roof drip molding rubber Locktite PLS30 Sealant black polyurethane caulk
Those grooves with loose rubber inserts look like rust generators to me. I'm considering replacement from 295 ml tube of "Locktite PLS30 Sealant Roof and Flashing" black polyurethane caulk.
Roof drip molding patm DIY / Maintenance / Service 1 05-20-2013 12:31 PM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 10:03 AM
Yaris 2 door Hatchback Thule roof rack question dasnake Cosmetic Modifications (Exterior/Interior) 5 03-22-2012 01:15 PM
Roof Racks and FE noraebong Fuel Economy Forum 7 03-23-2010 03:40 PM
Highland Roof Racks(?) YAR1S Cosmetic Modifications (Exterior/Interior) 3 12-07-2009 04:40 PM
