play every day
pics of a TRD intake installed?
Does anyone here run a TRD intake... and if you do, could you post some pics of where the air box is located when it's installed?
Thanks! ![]() I like the long straight intakes for better low end... but not the fact that the car needs to be disassembled just to service the air filter. |
#2 | |
![]() Drives: Toyota Yaris Join Date: Oct 2010
The air box I assume you mean where the cone filter is located between frame Rail an wheel well. 1)The tubes are a snap to install 2)all you have to do Is jack the car up and turn the steering wheel left completely. 3)look inside the wheel well on the liner youll see buttons(center removal of button with flat head screw driver you do not have take apart snaps slide middle out and pull entire button out) you have two snaps to undo and one bolt philips no 2. (star) underneath that holds the lining of the wheelwell to the bottom of the bumper once that's of you can peel back liner And install the cone filter . Remember to disconnect negative battery terminal when you install. Sorry no pics but honestly it is a really simple install take your time and enjoy the experince .
Thomas Paine Stage One Yaris TRDsway bar, TRD springs & shocks, TRD Quick shifter kit, TRD CAI, TRD oil & coolant cap Microimage light crank pulley, Agency Power steel braided brake lines. |
The TRD is exactly like other aftermarket cold air intake designs that are available. The longer pipe passes through the inner fender well and the filter sits in the wheel well, protected by the fender liner. We sell a ton of the Injen intakes; the price point is better than TRD and the quality is every bit as good.
#4 | |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Garm is permanently high because he is the king of smokin' deals! |
#5 | |
play every day
![]() Is this your TRD intake? These are listed on ebay. Do you have any trouble with water? Where I live, we occasionally need to drive through flooded roads. |
#6 | |
play every day
![]() Thanks so much for the long studs. They worked perfectly with 5mm spacers. The closed end splined Gorilla lug nuts didn't bottom out. They have a full 13 turns when they are tight on the wheels. It was a simple installation. I just tapped out the old ones with a brass hammer and pulled in the new ones with a spare lug nut and a pile of washers. I think I'm going to forgo a fenderwell filter because up here we get flooded roads. Do you know if anyone has hacked off an Injen and put the filter in the engine bay? |
^ You are describing a short ram intake instead; AFE is the best one and we keep it in stock. It provides an airbox with the kit that helps keep heat and dirt away from the filter.
play every day
I like the AFE dry filter, but don't like the two 90 degree bends. On the other hand I like the straight K&N, but don't like the oily filter and the price. The Weapon R looks really cool even though it has one bend, but I don't like the foam filter...
...so instead I modded my stock air box until I decide whether or not to get another intake. ![]()
<3 my Vitz
Drives: 2007 Toyota Yaris Liftback 3dr Join Date: Nov 2011
Nice!
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Be sure to remove the carbon trap filter thats riveted in the air lid.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
play every day
Thanks, Malibu...
![]() I was able to remove it intact by grinding off the heatstamped nubs with a Dremel tool. |
#12 | |
Trouble with to date no and I do not expect any water problems either. Injen is an excellent brand I had it on a corolla great all around. I chose TRD because that's what I wanted. pick what you like research and enjoy Flooded roads. I agree with others short ram is best water higher than14" and your engine is drinking water. Cheers
#13 | |
play every day
Thanks for letting me know.
| trd cold air intake | provost700 | Performance Modifications | 10 | 12-10-2010 02:30 PM |
| FS: Many goodies, stereo, speakers, AEM intake, TRD filter, parcel, LED lighting | Littlefoot | Items for Sale by private party | 1 | 05-09-2010 10:28 PM |
| FS: TRD Cold Air Intake | 33OH | Items for Sale by private party | 14 | 05-15-2009 03:30 PM |
| Pics of Recaro SRD's installed... | reznunt | Photo-Video-Media Gallery | 11 | 09-10-2007 01:42 PM |
| PICS OF TRD INTAKE INSTALLED! | elsteverino889 | Performance Modifications | 9 | 03-03-2007 04:12 PM |
