![]() Drives: Acura TSX Join Date: May 2012
Help me Decide - Yaris or Scion xa?
I currently own a 95 e36 m3, which is an amazingly fun car. However, with a car like that it is often a love have relationship depending on what needs to be fixed and what breaks. I average about 22 mpg with premium so I am ready to make the switch to a newer, more reliable, and more economical car.
I have narrowed it down to the scion xa and the yaris, but they seem very similar so it is difficult for me to decide. For those of you that may have looked into, or tested both, what swayed your decision? I am trying to budget about $8k so with that in mind would I get more from one or the other? I used to have 2 miatas so I definitely can enjoy and appreciate small lightweight underpowered cars as long as they are a little sporty and have a little fun factor in the handling department. Does the Yaris clearly get better average mpg compared to the scion? Has anyone bought a salvaged one with pictures and receipts proving the work that was done? Thanks for all your help in advance. |
Mr. 155 and climbing
Are you looking for a liftback or sedan? Either way you want the manual and not the slushbox. The slushbox sucks the F U N out of fun. This is of course in regards to the Yaris. If you are looking for opinions then you might also want to register on microimageonline.com also since it s a forum for small cars in general:
http://www.microimageonline.com/forums/register.php
I am looking to get a hatchback yaris not the sedan, and I would prefer a manual transmission for each. Would these cars be considered fun with some decent suspension items like shocks, springs, and sway bars?
yup...could be considered very fun especially if you boost via SC or turbo.
Apart from the packaging, they're virtually identical, though if I am not mistaken, the xA comes with a shorter final gear, so you'd have slightly better acceleration at the expense of higher RPMs at highway speeds. There are several xA owners here, I would wait and see until they chime in :)
Only Happy When it Rains
both are great cars. I think the xA is based off of the older Toyota Echo, but I might be wrong.
The differences are small, and it is almost just as good to let the best deal make the decision for you.
Colin Chapman disciple |
If I had the chance, I'd take my xA back over my Yaris in a heartbeat. It was just a better overall package...more leg-room, more features, better acceleration, better handling (at the slight expense of ride comfort) and better styling inside and out IMO.
If you want to enjoy your car, stay off of the internet. Last edited by Billiam; 05-23-2012 at 07:42 PM. |
![]() ![]() ![]() Drives: Black '08 Yaris Hatch S Join Date: Aug 2011
how was the mpg in the xA? ( i don't know jack about them)
-Will- |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
My wife had the 2005 xB before I bought the 2008 Yaris.
For driver comfort and ease of service the xB was slightly better. But the Yaris gets better mileage and was a better value for the purchase price. For my long commute, the Yaris is a necessity and still fun. (even better with a rear sway bar added) |
less gloveboxes on the xA though ;)
Overall it was about the same...despite the the higher highway RPM. There is almost nothing compatible between the xA and the gen-1 Yaris aside from wheels....though the xA can accommodate wider rims and tires. Intakes, exhausts, suspension parts will not interchange. But there are parts-o-plenty out there for the xA. The biggest powertrain differences between the xA and Yaris are the xA's lower final drive (in the manual tranny) and it's cable controlled throttle.
If only I had known where I'd be...I'd still have that xA.
If you want to enjoy your car, stay off of the internet. |
![]() ![]() ![]() Drives: 2007 Liftback Join Date: Mar 2012
I had a similar debate back in March, I really liked the xA, but the Yaris left me cold.
However, I ended up finding a Yaris with all the options I wanted, newer, with lower miles than the xA I wanted to buy. - Yaris has a less busy ride, especially sedans - Yaris is geared taller and is less noisy on the freeway while returning better economy - xA isn't available with cruise, unless you go aftermarket (strong deciding factor) - Yaris is a newer, stiffer platform. I remember being slightly turned off by how buzzy the xA was on the freeway; at around 75MPH it was turning nearly 4K RPM, IIRC. The xA does have sharper steering, but the Yaris is the better handler; it's kinda soft but it grips better. The xA is fairly tall feeling, and some corners it can be a bit unsettling. |
Also, the Yaris has better freeway economy. I get around 42, and the xA is a little worse.
I felt like my xA was the better handler, for sure. But that just my opinion.
Asif
Drives: Toyota Vitz Join Date: Dec 2012
Decision
no brainer, go for Vitz or Yaris. i have driven IST/Scion i does not compare, you will be much happier when you see your fuel bill at the end of the month.
I already drive one boxy vehicle, a Jeep. I don't see how anyone can consider the "styling" of the xA to be better than the sleek lines of the Yaris is beyond me...
Damn...old thread revival!
![]() This was not a comparison between the iTs and the Yaris...but the xA and the Yaris. Having owned both...the xA was easily the better car.
^^^^^ This (but if a black interior was available in Billiam's vintage of xA, and Billiam's pics give a good indication of the quality/design/fit of the seats, I do like those seats better than any stock Yaris seats)
| For Saie: Tanabe springs 2008 up Scion XD 2007 up Toyota Yaris | KSIbucky | Items for Sale by private party | 0 | 07-13-2011 02:11 AM |
| Toyota Yaris Scion xB xA Stock ENGINE COVER OEM | justoneyaris | Items for Sale by private party | 11 | 12-04-2008 08:05 PM |
