Pulley Squeak
I just put in a new pulley from micro image and now the belt is squeaking against it. Makes my engine sound like Donkey! Solution anyone?
"Because it's Racecar" |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
did you check and make sure that the alternator was pulled back to it's original position and did you make sure that it is aligned correctly. If it is a little off it could make some noise on when the belt rubs the A/C compressor.
Just take the bar to change your tire with and wedge it between the alternator and mount and pull back on it while tightening the bolt on the alternator to lock it in place, did so with mine and it stopped the squeaking. Also make sure your belt isn't damaged, didn't notice mine was damaged and it completely snapped while I was driving and my engine overheated :)
a.k.a. "Aothachos"
I had put a mark on the alternator and the bracket before i loosened it to take it off. The belt still looks ok from what i can see. It starts to make it once the engine get warm.
You should re-tension the belt, regardless of where your mark was.
and do not under any circumstances spray anti-squeal in there... I had a squeaking problem too, thought it was already too tight so tried that stuff, and well... belt disintegrated not too long after...
^ well it quit squealing once it wasn't there anymore
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
Haha. Thats one way to fix it! Ill try tightening a bit more a see. I pulled on it and it seemed really tight, almost to tight if you ask me Thanks!
Ok, so I tightened it. It pulled about a half inch or so but it still squeaking. I dont have any way of checking the tension but i know its snug now. Anymore suggestions? WD40...A new kinda belt, Haha. I think when I get home tomorrow Im going to take it off and have another look.
Was the pulley 100% installed correctly? Torqued to 95 ft/lbs.? Just checking.
Yep, went and bought a torque wrench just for it. I listened today when my lady got home from work. I think it may have stopped. I'll have to get back to it when i can. Thanks
| FS: NST 20% Overdrive Alternator Pulley | MGargano | Items for Sale by private party | 12 | 06-05-2011 11:06 AM |
| FS: 2009 Alternator & Overdrive Alt. Pulley | MGargano | Items for Sale by private party | 9 | 10-28-2010 07:42 AM |
| Gearbox/diff squeak, poor engine braking | Kiz | DIY / Maintenance / Service | 8 | 08-01-2009 09:35 AM |
| NST (NonStopTuning) Ebay Feedback & Rating | NonStopTuning | NonStopTuning | 0 | 07-19-2009 10:11 PM |
| NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) | NonStopTuning | NonStopTuning | 266 | 09-29-2007 02:51 AM |
