Old 05-31-2012, 08:28 PM   #1
yours_falsely
yours_falsely's Avatar
Drives: 2008 Yaris sedan
Airbag indicator
Alrighty, well more misfortune came my way today as I was involved in an accident. Nothing major, I was rear ended by someone who was rear ended. Some minor rear bumper damage is all. BUT! ever since, the airbag indicator won't go off. The one on the dash lit up and the passenger airbag indicator as well. Also, the passenger seatbelt flashing light won't stop flashing. Any ideas how I can fix this?
yours_falsely is offline   Reply With Quote
Old 05-31-2012, 09:13 PM   #2
Did one of the airbags deploy? If not, the flashing passenger light indicates an issue with the occupant classification system for the passenger seat. Under the front of the passenger seat is a small black box with two connectors. Check to see that they are still plugged in.
This thread explains how to make the SRS ECU flash the main SRS light in a pattern to indicate the trouble code for the system, which takes the guess work out of it:
http://www.yarisworld.com/forums/sho...d=1#post557473
Old 05-31-2012, 11:36 PM   #3
yours_falsely
Well I checked the box under the seat and they are still plugged in.
Old 06-01-2012, 06:26 AM   #4
Then, it's time to read the stored codes.
Old 06-01-2012, 09:30 AM   #5
yours_falsely
Alrighty, is there a list somewhere with the codes and what they mean?
Old 06-01-2012, 09:33 AM   #6
Yes. In the SRS section of the service manual, which can be downloaded from the Micro Image Forum:
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 09-27-2012, 05:53 PM   #7
Leesam
Drives: 2008 Yaris 3 Door
I got rear ended this past weekend. I'm in a similar situation now. It's flashing error code 32 now.
The airbags did not deploy during the accident and someone was sitting in the passenger sear at the time of the collision.
I tried clearing the code using methods posted in this forum and i got through it without issue (to where the light flashes steady at the end of the process) but light still wont turn off.
I checked the connections under the seat, they were properly connected and didn't look like they had been tugged on or anything.
Leesam is offline   Reply With Quote
Old 09-27-2012, 09:18 PM   #8
That is odd. You are not the first to have to OC system have issues after a collision. Unfortunately to diagnose it beyond getting the code 32 requires the Toyota Techstream tool.
Old 09-28-2012, 07:47 AM   #9
Leesam
I figured it would, thanks for the reply!
Old 09-28-2012, 06:10 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
Hey please please please post your threads in the proper category! I've been moving at least 5 or more threads a day to the proper categories. I've moved it for you but PLEASE next time post in the correct spot.
Old 09-28-2012, 06:11 PM   #11
Astroman
Modded Moderator
Astroman's Avatar
Hey Leesam, are you by chance from Quincy Washington?
Airbag light won't turn off dubgil DIY / Maintenance / Service 128 08-03-2016 01:12 PM
Passenger Airbag Question RedStickHam DIY / Maintenance / Service 13 06-23-2013 04:39 PM
Replace airbag in my 2007 Yaris uglyducklin DIY / Maintenance / Service 2 01-12-2011 02:53 PM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
WTB: Driver Airbag, Airbag Control Module, Upper Tie Bar opdmize Willing to Buy by private party 1 03-19-2010 01:01 AM
