![]() ![]() Drives: 2007 Blzng Blue Yaris Liftback Join Date: Nov 2006
Help with Amp Ground in Trunk
So i'm installing one amp in the trunk to power the sub, i have the power routed from the battery, all fuses are good, and the remote wire connected but the amp just won't power on. I'm almost sure it's just a bad ground. I used the bottom right bolt in the picture. I used a dremel to expose some metal. I don't know if it has anything to do with it but the bolt screws into a plastic piece. If anyone has any insight to trunk grounds please help. I think what i will try is maybe one of the seat bolts, but what kind of socket does it require as it is shaped different. Do i need torx sockets?
Thats where I grounded mine except on the lower left of that pic. I got the metal good and clean and had the same problem as you. So what I did was put a washer between the plastic on the ring terminal underneath. Also I took the edges off the black plastic piece that is in the edges to make sure my ring terminal touched all the way around. I didnt take all the edges off it just enough so my ring terminal would sit flush all the way around. After that I had no problems.
PS: I couldnt find a washer so my "washer" ended up being a pop can tab. Hey, it worked. |
![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
check one of the tail lamps ground, it may work...
20 years... alive and kickin'!! ![]()
![]() ![]() Drives: 07 Yaris Hatch 5speed Join Date: Nov 2006
Technically, you shouldn't use a bolt for something else for the ground. I sanded down an area, drilled a hole, and used a sheet metal screw.
But I don't think your problem is the ground. Double check your remote wire to see if it's putting out (hehe). If you don't have a voltmeter, use a jumper(a small piece of wire) and hook up the remote input to the battery input on the amp. |
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3 Join Date: Oct 2006
had to drill a hole into the chassis. didn't sand it or anything. sub sounds great.
ouch...
| amp wiring question... | Keymaster | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 02-03-2007 10:01 AM |
| Trunk issue | Lowfront | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 09-24-2006 06:55 PM |
| Custom Sub Enclosure (inc sub, power cap, amp) | wado | Items for Sale by private party | 3 | 09-18-2006 11:53 AM |
| Where did you ground to?? | ptwnluv | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 08-07-2006 11:42 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
