![]() Drives: Toyota Yaris T3 Spirit Join Date: Jun 2012
Instrument Panel Fuse box location?: Yaris T3 Spirit
My Instrument panel/ dashboard is not lighting up.
I believe its a burned fuse. Where will this fuse be located? Thanking you in advance |
Is your T3 a first or second generation Yaris?
If it is a 2nd gen (06-11), then the fuse box is located under the bottom of the dashboard on the driver's side of the car. You would check the PANEL 1, PANEL 2 and MET fuses. If it is a 1st gen (99-05), then the fuse box is located behind the small storage cup on the lower dash on the driver's side. On the 1st gen the TAIL fuse supplies illumination power to the panel.
Thnx for the reply,
It is a 2nd gen. but did not find it where you suggested. I located a fuse box behind the glove compartment, but it is not the one that has the fuse that im looking for. any other place? |
Look under the bottom of that fuse panel.
| Check out this yaris panel!! | marcus | General Yaris / Vitz Discussion | 11 | 10-25-2006 03:28 PM |
| Centre Panel Yaris Sedan | dngz | Cosmetic Modifications (Exterior/Interior) | 19 | 09-05-2006 05:00 PM |
