#217 | |
Only Happy When it Rains
Colin Chapman disciple |
#218 | |
FYI, Over 4 years on my OEM headlight bulbs with DRL's operational. Chances are the lower voltage used to run DRL's slightly dimmer than full headlight power does little to steal there life.
#219 |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Aug 2011
Owned my Yaris since July 28, 2007 and it has DRL's. Both headlights still working fine.
When I was out last Sunday, driving down a country road, I noticed a car coming without DRL's. It was a sort of grey/black colour that matched the colour of the asphalt. I thought about this thread and how hard it was to see this car without DRL's compared to how easy it would be to see it if it had DRL's. After having DRL's for 23 years here in Canada, I think DRL's are right up there with sliced bread. To good of a safety feature to do away with if you have them. MY 2 cents worth. Roy |
#220 | |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
I know that particularly when it is raining .. that having your lights on can make all the difference between being seen and not. There will always be people that don't like to be told to do something .. and it is their business what they want to do when it comes to things like DRL's. I personally am happy that I have something that is working to keep me safe while driving. Enough said .. and as this thread indicates, it is to each to decide if they want to have DRL's on their cars. |
#221 | ||
If you took out all the mandated safety garbage of the Yaris you'd have the car weighing at least 200 pounds less, probably a lot more. That means the car could do everything better, including better gas mileage and being able to avoid accidents better. It would also cost less, by thousands. If you like drl's, good for you, you should be able to have them. if you like abs, or air bags, or traction control, or any other safety nanny, you should be able to buy it. But there is no reason it needs to be forced down my throat too, because it hurts the car in every way possible for a maybe that doesn't happen very often statistically. A choice is one thing, deciding that everyone else is too stupid to make a choice is a whole different evil disgusting thing.
#222 | |
I do agree that it is better for people to have choices (and this thread recognizes this by allowing people to make their own choice). I personally like the safety features that my Yaris has (and I'm more than happy to pay for them) .. as being a subcompact, you are probably smaller than the other party in a collision, and I want all the protection I can get whether it is airbags, abs etc. You are lucky you don't live in Canada .. as we tend to be a more submissive society and as such we have to live with some things we may not always like. But given a choice .. I wouldn't want to live anyplace else. |
#223 |
![]() ![]() Drives: Toyota Yaris LE HB 2008 Join Date: Apr 2012
Just did this little surgery, took about 10 minutes, so easy to do and NOW I will be the master of when I want to put my DRL on or off...
#224 | |
Not what I would have recommended. But everyone has the power to do as they please. It is a free country. |
#225 | |
It is more than a bit ridiculous that cars like the Honda CRX and that gen Civic could not be made now because they wouldn't have all the government mandated garbage. Totally absurd. Cars are getting heavier because of all this, which is hurting gas mileage and what is even worse is that it really can't be proven any of it actually saves lives. And at the same time the government is trying to mandate insanely high cafe standards, basically fantasy numbers at this point.
#226 |
![]() Drives: 2007 yaris Join Date: Feb 2012
Sorry to rez this thread from the dead, but I recently installed an HID kit in my wife's 2007 Yaris LB (canadian model) and have the problem from the OP where the HID's flicker when the DRL come on...
Is there anyway to retain DRL functionality but not cause undue wear on the ballasts for the HID kit? |
#227 | |
#228 |
Drives: 2007 Yaris 3 door Join Date: Jun 2014
Great Job!
Solves the problem and very good photos.
It is way too easy to accidentally leave your headlights turned off when the daytime running lights are so bright. Not such a problem driving, but very bad from the rear because your tail lights don't come on with the DTRL's. I nearly got a ticket for not having tail lights but got away with just a warning when I explained what had happened. So thanks again for a job well done. |
#229 |
![]() Drives: No longer own a Yaris Join Date: Jul 2014
I didn't remove the relay, just unplugged it. Can someone tell me how to disable the little lights in the head lights when the park "running" lights are on?
#230 | |
Unplugging renders the fog lights not working if you have them. Hand brake light will also stop working |
#231 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
I re grounded the fog light wire. Fogs still work for me
"It hurts more when its wet" |
#232 |
Exactly. There is a DIY on here for disconnecting the DRL module and jumping the one wire to re-enable the fogs. All other lights (and the ebrake indicator) will work fine with it disconnected. The ebrake is actually just an input to it, so you can turn off the DRLs when parked
#233 |
#234 |
![]() ![]() ![]() Drives: No more Yaris Join Date: Dec 2013
Years ago I had a Matrix with those lights.
I found by putting a shunt on the Parking Brake switch, it would put the DRLs out - if you switched on the shunt BEFORE taking it out of gear (if you waited until you were in gear, the DSLs would stay on). Only downside is that the BRAKE warning light would be on. Actually not a bad idea, to warn you that you've got those DSLs off. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Toyota unveils 2007 Yaris T-Sport Concept | VitzBoy | General Yaris / Vitz Discussion | 63 | 01-21-2007 03:12 PM |
