Old 06-27-2012, 09:27 AM   #1
DamianShadowPaw
Drives: 2008 Yaris 4 door
Aftermarket Sway Bars?
I have a 2008 Yaris Sedan and i was wondering what the best performance sway bar for the rear is. i want it to be as stiff as possible. don't really care if it's adjustable or not.
DamianShadowPaw is offline   Reply With Quote
Old 06-27-2012, 09:35 AM   #2
Ultra Racing 23mm
http://shop.microimageonline.com/Ult...R-AR23-100.htm
Unfortunately, currently out of stock.
Old 06-27-2012, 10:14 AM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
the whiteline one (also at microimageonline.com) is pretty nice too. I actually have that one on my car. it has adjustments but I just put it at the stiffest setting to begin with. it has 2 holes for soft and stiff.
http://shop.microimageonline.com/Whi...-xD-BTR86Z.htm
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 06-27-2012, 11:45 AM   #4
TOLMACH
Drives: soarer
in case you have stock dampers - installing stiffer shock absorbers is a ten times better investment than just adding a sway bar
rear ones - 153 bucks shipped
http://www.ebay.com/itm/TOKICO-REAR-...4632a8&vxp=mtr
140 bucks shipped
http://www.ebay.com/itm/HP-Blue-Rear...5846a7&vxp=mtr
Old 06-27-2012, 12:51 PM   #5
Shocks and struts without springs isn't going to improve handling that much, especially body roll.
Sway bar is a huge improvement on the Yaris in turns. Either of the ones posted above are very good choices.
But, since it was posted above, we offer the FULL SET of Tokicos here:
http://shop.microimageonline.com/Tok...RIS-TBSS-Y.htm
Old 06-27-2012, 01:09 PM   #6
BEEF
BEEF's Avatar
I did the sway bar and the springs (I went with H+R) and there was a huge difference. now it is stiffer and body roll is way down. The total cost was around $500 (after the alignment and all)
http://www.yarisworld.com/forums/showthread.php?t=40153
good luck in whatever you decide to do.
***edit***
both items were purchased at microimageonline.com and they were great to work with. if you have questions, they have answers (but not crappy ones like radioshack, lol)
Old 06-27-2012, 01:41 PM   #7
TOLMACH
Drives: soarer
I have tokicos in the rear and the diffirence is HUGE.. (still waiting for my spring compressors to install the front ones).. installation of the sway bar only could not even compare.. i still have some bodyroll but the car feels completely different ..even my wife noticed the difference (that being said she has not noticed the exhaust so far). Based what I am hearing from people - intstallation of springs only is kinda half measure - more for looks, replacing just the shocks has a much stronger effect overall (you do not replace springs each time you adjust your coilovers' "stiffness" setting, right?).
tokicos are easily available from many sources (same as yours just 15 bucks cheaper = price of the spring compressor tool)
http://www.ebay.com/itm/130414949004...84.m1497.l2649
Old 06-27-2012, 01:57 PM   #8
BEEF
BEEF's Avatar
TOLMACH, do you have a sway bar?
Old 06-27-2012, 01:59 PM   #9
TOLMACH
Drives: soarer
yep, trd one
First installed the sway bar.. its presence is noticeable but is basically nothing compared to just adding two decent shocks in the rear (in my experience)..
Old 06-27-2012, 02:20 PM   #10
BEEF
BEEF's Avatar
funny, you didn't even mention how you liked the TRD sway bar.
The OP was asking about sway bars. why not give him your opinion of that vs telling him about other items.
Old 06-27-2012, 02:31 PM   #11
TOLMACH
Drives: soarer
There are lots of opinions here on most sway bars that are presently on the marker. My concern is that most people (including myself) expect some sort of miracle installing one.. the truth is- there is no miracle just minor improvement.. you really need to have couple stiffer shocks in the rear
Old 06-27-2012, 03:16 PM   #12
Your YarisWorld sponsoring vendor, me, will match any unknown eBay seller's price. Just call us.
We're the BEST source.
Old 06-27-2012, 04:16 PM   #13
On stock springs/shocks/struts, my first impression of the rear sway (TRD 19mm) was that the car felt 'heavier'. Heavier meaning that it felt more firmly planted to the road with less tendency to float. This was way back in 2008 before the forum could plant a lot of preconceived notions of what I should be experiencing.
Old 06-27-2012, 04:43 PM   #14
MUSKOKA800
MUSKOKA800's Avatar
I installed the TRD sway bar on my '08 sedan prior to any other suspension bits. It made a huge difference in highway stability and also greatly reduced body roll and understeer through corners while leaving OEM ride quality.
A month or so later I added the rest of the TRD suspension components which took the ride quality from OEM comfy to super-sporty.
Most my age are looking for a Cadillac ride. I still prefer to have the fillings shaken loose from my teeth. The price I pay for road-race type handling on frost heaved Canadian roads.
Old 06-27-2012, 07:30 PM   #15
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
The Whiteline bar is the most popular, probably because everyone knows the companies name, but the forum goers here love the Ultra Racing one. I am pretty sure it was noted a while ago you could actually run both at the same time if you really wanted to.
They are both good, and do the job. Plus they aren't really that expensive compared to shocks and springs, and they don't give a bone jarring ride like shocks and springs do.
Colin Chapman disciple
Old 06-28-2012, 05:06 PM   #16
DamianShadowPaw
I'm don't really care about the ride being bone jarring, i would rather it perform well. comfort is not all that important though i would like to find some nice adjustable shocks, maybe something like the QA1's that you can adjust the firmness with just the turn of a knob.
Old 06-28-2012, 05:43 PM   #17
Adjustable shocks and struts would either be the Tokico Reds:
http://shop.microimageonline.com/Tok...ks-HTS-116.htm
or shocks/struts that come with several of the coilover kits, like Megan, Cusco, KW, Silk Road, Ohlins, etc.
(Tanabe and Tein Street Basis coilovers do not have adjustable damping)
I currently have a set of nearly new Silk Roads available for $1400 shipped.
Gauging Interest: Whiteline Front/Back Adjustable Sway Bars RaptorRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 12-15-2009 05:23 AM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-09-2009 12:26 AM
WTB: Sway Bars (F&R) ozmdd Willing to Buy by private party 2 04-09-2009 11:57 AM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 10:54 AM
Need some input...sway bars Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 04-23-2007 05:16 PM
