#37 |
ah it's not that great, 180 degree bends are not exactly good for air flow!
#38 | |
Ecurie Snoopy Lives
Was there any reason you had it installed?
Sponsors and Organizations: Toyota Rally Canada Yokohama Tire Canada Western Canada Rally Association Ecurie (Team) Snoopy Canada, racing since 1966 ![]() |
#39 | |
Doctor Drive Little
I agree with you! Sound good when you shift up or kick down for accle! Torque coming and rpm running faster than factory filter and intake box.http://www.yarisworld.com/forums/ima...245/N63025.jpg |
#40 |
![]() Drives: NCP91 Join Date: Apr 2007
Very nice simota air intake
Do you got any idea for this model ? Is your engine oil get dark easier? and yr cusco oil tank is help to make your engine room clean is that right? |
#41 |
Ecurie Snoopy Lives
I've got my oil catch tank installed and wanted to find out about the tubing on your car.
The blue tubing from your catch tank that attached to the top right hand side of the head cover. Is this tubing really hard and doesn't soften with the heat the engine and header makes? I've had two types installed already, one harder than the other, but even the harder one still collapses like a vacuum is sucking it shut. If you can tell me what kind of tubing you have. That'd be greatly appreciated.
#42 |
![]() ![]() Drives: Yaris Join Date: Jun 2007
What all did you buy to have that set up? obviously more than the filter right?
#43 |
Looks good! I like that intake design!
An oil catch can is usually to go between the valve cover and intake pipe or PCV valve and intake pipe. It's function is to remove oil and or oil vapor from positive air coming from the valve cover and oil vapor induction in the intake. Usually you don't install these unless you have blow by. I don't have blow by on my engine but I wish to have clean intake. Oil vapor can lower fuel octane significantly. You can fabricate one for under 20 dollars. |
