#379 |
hamchk
I had a 98 Tacoma and 2 two years ago Toyota recalled it because of a rusty frame. They bought it back KBB plus 2%. GM did not buy back my old rusty S-10.
#380 |
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Toyota has had a remarkable run with very few problems over all. With the economy on the skids and US car manufacturers clawing to stay afloat it's only natural to blow the Toyota recalls up all out of proportion so they can use it to gain some sales traction. Any company the size of Toyota will have issues from time to time. They will survive this as they have huge consumer loyalty. When this recall is over and the press moves on, consumer confidence will bounce right back. Lets watch for the next GM recall.
#381 |
[QUOTE=auxmike;435171]I'm sure most of you have seen the news about the "sticky" gas pedals recall on the way.
THANK GOD the Yaris is not on the list. We also did'nt get hit with the floormat thing either. This does not bode well on Toyota. Two problems with potential runaway acceleration with in a couple of months, that sucks! [/QUOTI found it "unusual" that none of the Toyotas made in Japan had any problems! I also found it "delightful" that of the American Cars only Ford did not borrow money. When the Congressman asked the Ford Executive, "You don't want to borrow any money, so why did you come here?" " I'm here Sir because you told me come here!" |
#382 |
![]() ![]() Drives: 2009 Toyota Yaris Join Date: May 2009
I got a recall on my 2009 Yaris today. Basically a label for the load carrying capacity is either incorrect or was left off altogether(I haven't gone out to check yet). What I have to do is put the new label they sent me on the inside of the door jamb. According to the label they sent me, the carrying capacity of my car has been reduced by 12 lbs!
Did anyone else get this one? RedStickHam |
#383 |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
I just noticed that label on my 2010
I was wondering what it meant. It's a Yellow label, right? |
#384 |
![]() Drives: 2007 YARIS 3 DR HATCHBACK Join Date: Oct 2008
Have you tried a "I'm a dissatisfied Toyota custmer" picket sign in front of a Toyota dealership...this will get thier attention and they can't hang up on you.
#385 | |
Modded Moderator
#386 |
I got a letter in the mail today saying there was a minor issue with the rostra cruise control unit I had installed. Apparently under some extremely specific circumstances using a 2-way radio and emergency frequencies the engine speed (RPM) can fluctuate mildly and cause the check engine light to come on.
Toyota and Rostra have separately investigated and found no safety issues, but are recommending it be removed, and they give me a refund in full for what I paid for it. I might see if I can get them to install the OEM cruise control using the money they'd otherwise be refunding to me. Not only do I hate the position of the rostra unit, but I would miss my cruise control terribly. I will scan the letter and post it here soon. edit: looks like it's been reported already http://www.yarisworld.com/forums/showthread.php?t=31279 Last edited by teddy; 10-20-2010 at 09:07 PM. |
#387 |
![]() Drives: none Join Date: Nov 2009
Some generations of yaris have been made in France?.
[SIGPIC][/SIGPIC] |
#388 |
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
Yup, including early models of the current Yaris sold in the EU. Mine was produced in Japan, for instance.
Terveisiä lahden tonne puolelle, muuten :) |
#389 |
![]() ![]() ![]() Drives: yaris 2 door hatch Join Date: May 2007
I have a 09 camry never a peoblem with this one. 07 yaris its more fun to drive.
#390 |
I've also have a 2009 camry never any trouble. When they sent the recall notice I filed it in the trash,
#391 |
![]() ![]() Drives: 2010 yaris sedan 4 speed auto Join Date: Apr 2012
I have the 2010 sedan. windy day on test drive but more play on freeway than my 94 geo metro aka suzuki swift. doesnt settle down on freway and wanders abit. same complant and recall as corolla drivers. power assit sterring on ecu set to high. only real fix is to try rear sway bar to fix turn and wander at higher speeds I guess. called my people at Big O Tire and they said no ajust for caster of front wheels lowering springs is next . will post next month when I can save up for sway bar at amazon about 250 total fix.
#392 |
![]() Drives: 07 Yaris 3dr, 09 Yaris 4dr Join Date: Sep 2011
Any Recall For VVT Oil Leak?
[B]I have heard that Toyota had a recall out for camrys because of a leaky VVT oil supply line. The oil line that sends oil to the VVT hydraulic cam gear can develope an oil leak. Apparently, there is a plastic or rubber part of the oil line up near the head that starts leaking. Does the Yaris have such a recall?
#393 | |
If you want to enjoy your car, stay off of the internet. |
#394 |
![]() ![]() Drives: 2010 3dr hatchback auto red Join Date: Jun 2010
NHTSA probes Toyota drivers door window switch
http://bottomline.msnbc.msn.com/_new...-million-autos
According to the National Highway Traffic Safety Administration, the automaker is looking into reports that the window switches on the driver’s side doors of a number of different Toyota models can overheat and catch fire. The problem has so far been linked to 161 fires and nine injuries. This includes some Yaris subcompacts from the 2007 to 2009 model years. |
#395 |
I got a 2009 camry also never a problem. Never took it back for B/S recall. Better a bad Toyota than a good Ford or Chevy what ever that crap fait makes.
#396 |
Aygo Crazy
Drives: '08 Blazing Blue LB MT Join Date: Oct 2008
The window switch recall is in. 7.43 million vehicles including the Yaris.
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 04:36 PM |
| Toyota Temporarily Suspends Sales of Selected Vehicles | redglare45 | Off-topic / Other Cars / Everything else Discussions | 0 | 01-26-2010 06:33 PM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 03:16 AM |
| Toyota recalls vehicles over faulty engine | Lizardboy | General Yaris / Vitz Discussion | 1 | 07-18-2006 07:07 PM |
