![]() ![]() ![]() Drives: 2008 5 Door Liftback Auto Join Date: Oct 2011
23 mpg...really???
Everyone here seems to talk about how great a mileage they get, but how about this: my last tank was 23 mpg. What the...?
A tank just before was 29.5. Not stellar either, but 23 is ridiculous. It's a 08 auto with low mileage and no problems whatsoever. TB cleaned a couple of weeks ago, MAF is clean, tires are properly inflated, injectors cleaned off car just this winter. Driving style: grandpa. 99% city, often with wife and two small kids and AC on 100% because it's been very hot and humid. I understand it's going to affect the mileage, but 23...how are you guys getting high 30s in all city driving? My personal best is 34 when I was driving mostly highway. I am tempted to get the at fluid changed even though it's far from due. Other than that I just don't know anymore..
1999 Honda Prelude Base 5 speed (summer driver) 2008 5 Door Liftback Auto |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
Where in Canada do you live ? Calgary ... the drivers there are terrible.
Mr. 155 and climbing
I would usually lose about 3mpg with the AC cranked 100% and using it constantly as a point of reference. I am not saying that the 23/24mpg is acceptable for city, just giving you a point of reference. Perhaps an ECU reset by disco the battery for 30 minutes or so to make it relearn your long term fuel trim may help? Other than that have a scangauge connected to see what is happening during load.
It can happen. I've gotten very close to that low myself.
Since you haven't stated where in Canada you are I'm going to assume your weather conditions are what I've been experiencing this past month. Constant >30c heat. At these temps, the air is very thin and combustion can be air starved resulting in less efficiency. Combine that with 100% A/C, 99% city, and often a full passenger load and you will suffer. This engine hates A/C (and weight). Most of the people touting high mpgs are not running constant A/C, and are almost always the single occupant of the vehicle. My last fillup, yesterday, saw 27.85 mpg. That was mostly city, with very little use of the A/C. Edit: Just check another thread. You are in the GTA and living the same conditions as me.
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
OP please tell us how many KM you get for a full tank.
I dont know my mileage but I get about 430-460km (depends how hard i drive) then the last bar flashes. Also the stupid ethanol contributes to our fuel mileage too, |
#6 | |
This time around I went to 2 bars and if I remember correctly the trip was 270 or so...the number of liters that I put in was about the same as km traveled. Normally I go by half-tanks and on bad fillups like this it is around 210 km. On better fillups I get maybe 250. The drivers here are pretty average. I almost never have to brake hard.
#7 | |
Btw, no need to keep it disconnected for 30 min. I tried disconnecting for a few minutes and it got the long term trims zeroed just fine.
#8 | |
EDIT: which tread are you referring to?
The List of GTA Members thread in which you indicated Thornhill.
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
Bad O2 sensor perhaps ?
I have 08 Yaris HB , 30xxx mi on the odo, supercharged with aftermarket adds on. 17" wheels and Use a/c all the time and still getting 33-36 mpg..... That's with an O2 sensor CEL code tho ... (ordered the new part n waiting to arrive) |
going on half tanks or other partials can be very subjective. with how much the fuel moves around in the tank I have personally experienced divations anywhere from 5-20 miles on the OD and have tested by actually refilling after 2,3, & 4 bars down. Add in the heat/humidy indices and it can really wreak havoc on FE. I had a couple tanks while in Memphis in 08 and then again in central AL last summer that were very similar to your experience during the dog days of summer. I also had a few tanks the last couple winters where I avg around 22/23 as well. It sucks, but it can happen.
Oh that. I misunderstood you. Yes, I am at the very south part of Thornhill.
#13 | |
#14 |
Yeah, I meant to say 'checked'.
#15 |
If the lambda sensor was off I imagine I'd see funny long term fuel trim numbers due to discrepancy between lambda and MAF sensors.
#16 |
At this point I'd say just sit and monitor for a while. Do more frequent smaller fillups so that you can do the math against a narrow list of environmental and physical variables.
#17 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Really humid air could be moisturizing the dirt on the filter and make it "pack" into the filter fibers and clog the filter reducing air flow and decreasing gas mileage. I've seen that happen on the return air filters of home central heat/cool systems. |
#18 |
^ the filter is only a couple months old.
Besides, I've been led to believe that in FE vehicles a dirty filter degrades power, not mileage. Fuel injection will compensate the injector pulse to keep the mixture stoich, i.e. with less air it'd inject less fuel. So, I'd imagine the net result would be the same as less throttle.
| Save thousands and BIG MPG almost PRIUS | jay cobbs | New YARIS Purchase Forum | 6 | 08-28-2012 09:38 PM |
| Why sub-compacts and compacts get almost the same MPG | Kal-El | Off-topic / Other Cars / Everything else Discussions | 0 | 08-11-2011 12:51 AM |
| 3000 mi Summer Trip Log...MPG included! | slothman86 | Fuel Economy Forum | 14 | 07-20-2010 01:15 PM |
| Better MPG in the City vs. Hwy | Loren | Fuel Economy Forum | 21 | 01-29-2010 12:49 PM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 07:31 PM |
