![]() Drives: yaris 1.3 tr Join Date: May 2012
yaris oil filter
hi i have a 2oo9 1.3 auto and am having trouble finding the oil filter housing and do i need a special tool to undo it,
thanks for your help
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
![]() With a screw driver. Create a noose put it around the filter then spin the thing tight around the filter.Then rotate the whole assembly I think it's anti clock wise. Last edited by junorico24; 07-18-2012 at 10:20 PM. |
![]() ![]() Drives: NCP91 Join Date: Jul 2012
The 2NZ-FE uses a canister-type oil filter: it screws onto the engine block beside the oil sump. You will see it clearly from underneath. No special service tools required for it, but tools do exist to make removal easier.
An effective DIY/household tools method of twisting off a stubborn filter is to hammer a punch or or stake or a similarly long, slender rod into its side and unwind it. Works every time and does not rely on a friction-based strap or pliers since it could be slippery from oil. |
Thanks for the reply but the filter on my car is an eco paper filter not the cannister type and there is no obvious housing.
The oil filter assembly on your engine looks like this:
Oil filter element.jpg There is a drain plug at the bottom, which you open first to empty it, and then you remove the canister to change the element (part number 04152-40060). The wrench for removing the canister is: Assenmacher Specialty Tools TOY 640 The canister is an odd size (64.24 mm), so the standard filter wrenches don't fit (64mm is too small and 65 mm is too large)
Thanks CTScott for your reply and the diagram both very helpful, will attempt to make the tool with a piece of pipe with two slots and a bar many thanks big donga from ongar uk.
#8 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
Hmm seems like a metal band oil filter wrench should work to grab the housing and turn it counter clockwise to remove? 64mm is ~2 1/2 inches. Metal band filter wrenches typicially accommodate filters from say 2 1/4 inches to 3 1/8 inches or similar.
2 1/2 inches is pretty small for an oil filter.....
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
| FS: Oil filter to suit yaris | mickd | Items for Sale by private party | 1 | 11-03-2008 07:55 AM |
